Author Topic: 899ci SI HD Recording setup?  (Read 8381 times)
Offline Rojo Guio
  • Unit(s): 383, 596HD DI, 899HD SI
« on: April 21, 2014, 07:58:02 AM »
Can someone post how to make the 899 record. I am only able to access SNAPSHOT. If the 899 does not record please advise which unit would be the best entry level recorder. We river fish crappie and would like to be able to map out bottom structures.
Re: 899ci SI HD Recording setup?
« Reply #1 on: April 21, 2014, 02:33:32 PM »
Rojo,
Unless you have hidden it, your 899 unit should show you the Snapshot and Recording View when you scroll through all of the available Views.  Go to this View and press the MENU button once.  You should see the Start Recording menu.  Activate It by using the Right Arrow button.  You will need a memory card in your unit to be able to do this.  Once the recording is started you can view any pf the sonar or GPS Views.  When you want to stop the recording it should be the first menu listed on all of the Views.
Last post April 17, 2014, 10:33:23 PM
Last post February 07, 2014, 02:36:26 PM
by Shane23ss
Last post February 08, 2014, 01:44:49 PM
by wallywatcher
Last post February 11, 2014, 05:20:38 PM
by jjbch
Last post March 21, 2014, 10:05:46 PM
by Brismith3
Last post April 20, 2014, 12:40:42 AM
by rsouza3
Last post April 22, 2014, 11:10:14 AM
Last post May 13, 2016, 03:58:11 PM
by D S
