Author Topic: Dual Transducer Setup for Bassboat application  (Read 21842 times)
Offline kjaquith
« on: March 25, 2010, 06:54:59 PM »
Best transducer for high speed in dual transducer setup.  Plan on mounting Side Imaging transducer at back of boat but have been told to run a 2nd transducer preferably shoot through hull for high speed.  A puck mount in the hull is prefered
is this what I need?   XP 9 20T
2nd question.
Is it best to run this off the side imaging Y cable (AS_SIDBY)   or with a switch?
Thanks,
Kevin
Re: Dual Transducer Setup for Bassboat application
« Reply #1 on: March 26, 2010, 08:03:19 AM »
Kevin,
Depending on whether you want to use the switch or the splitter Y-cable would determine which transducer you want to get.
Most folks don’t want to have to mess with having to mount than flip the switch when they need it and so go for the splitter Y-cable:
XP-9-20 inside-the-hull DualBeam transducer
AS-Si-DB-Y transducer splitter cable
This is the less expensive option.  The 2D sonar will always come from the inside-the-hull transducer.  Si sonar and water temperature will always come from the Si transducer.
If you want the switch than you need:
TS2-W Transducer Switch
XP-9-20-T inside-the-hull DualBeam transducer with temperature sensor on the end of a 10-foot cable
All sonar and water temp will come from whichever transducer the switch is toggled to.
Offline Jolly Roger
  • HB Addicted
  • Software: latest (mostly)
« Reply #2 on: March 26, 2010, 08:03:42 AM »
Hello Kevin and welcome to the forum!
1. Right, this would be the transducer you need to shoot through the hull:
http://store.humminbird.cust.shopatron.com/products/313994?product_id=8ca87a13d95db3e5c28a6f68dbb685ef
2. The AS-SIDBY cable will do.
Regards / Harry
YES,......
WE SCAN!
Offline blharr4400
  • Unit(s): 788Ci Combo 1197C SI COMBO
  • Software: 4.78 and 4.75
  • Accessories: Weathersense, Interlink
« Reply #3 on: March 27, 2010, 02:52:05 PM »
Kevin,
This is what is in my boat
1197C SI at the consoule
The HDSI transducer at the back of the boat in the center
This is on an 18'6" Triton with a 150 HP Mercury with an 8" jack plate.  The nice thing about the jack plate is it allows me to trim the motor all the way down and still have plenty of space between the motor and the transducer.  You can look at the installation pics of mine if you are interested.
With all of this said I can keep the bottom to speeds around 40 mph with no problems, between 40 and 50 it is stetchy but seems to pick up the bottom from time to time. 50 to 60+ there is nothing.  Having said all of that it also will pay to set the max depth on your unit to something around 200 feet as it will help you pick the bottom back up quicker as you come down off plain.
Hope this helps,
Ben
I wont always catch fish but they are never going to sleep through me being there!!!
« Reply #4 on: March 28, 2010, 10:23:22 AM »
Looks like the tranducer is a bit high..  but it seems to be working for you. Although maybe what I am seeing is the trailer and not the actual boat bottom.   Keep us up dated on how this configuration is working.  chuck
« Last Edit: March 28, 2010, 10:51:54 AM by sonar2000 »
Last post March 10, 2010, 09:31:10 PM
by soretoe
Last post January 03, 2011, 01:12:25 PM
by keizerh
Last post February 09, 2011, 07:45:17 PM
by mt72916
Last post April 25, 2014, 02:31:50 PM
Last post September 03, 2014, 12:11:17 PM
by Free2Fish
Last post March 25, 2015, 11:39:15 AM
Last post April 17, 2015, 02:14:36 PM
Last post July 14, 2016, 02:53:06 AM
by fishreed
