Author Topic: GPS Internal Receivers Not Working  (Read 14566 times)
Offline old humminbirds
  • Unit(s): 798ci si nvb 788ci 788ci hd
  • Software: 6,3 6.3 7.8
  • Accessories: none
« on: November 08, 2020, 02:10:49 PM »
I have four Humminbird units 798CI SI, (two) 788CI HD, and 788CI. All are combo units. Does anybody know if there is there an external GPS puck that can be used and hooked up to all of these units?
Offline danlaboucane
  • Unit(s): ,798 hd onix8 ct , solix 12 msi
  • Software: 7.6 ,3.03
  • Accessories: sm3000+eth 5 port to get SI on onix CT,
Re: GPS Internal Receivers Not Working
« Reply #1 on: November 08, 2020, 02:46:24 PM »
the gps and gps HS would work with them , with a y cable and to use it from all your units you need them networked
  • Accessories: none
« Reply #2 on: November 08, 2020, 03:47:46 PM »
The only two units I know can be networked are the 788CI HD's. The only way to network the 798CI SI and the 788CI is using interlink. I bought a used interlink and I cannot get it to work (I think it's a bad unit). So the only way I can use an external link is to buy three. One for 798, one for 788, and one for the two 788CI HD's. Am I understanding that correctly?
« Reply #3 on: November 08, 2020, 04:42:53 PM »
this is going to cost $$, maybe you should look into getting helixes with internal gps
Last post May 29, 2009, 09:07:30 PM
by panteradave
Last post December 14, 2009, 10:38:17 AM
Last post May 09, 2010, 10:09:46 PM
by ROOD
Last post July 13, 2011, 03:02:43 PM
by erhan
Last post May 14, 2013, 10:14:50 AM
Last post April 30, 2014, 05:54:53 PM
by Tr-196
Last post July 02, 2014, 01:32:59 PM
by alexpalmer1
Last post December 10, 2016, 04:38:28 PM
