Author Topic: receivers  (Read 11541 times)
Offline krappie1
receivers
« on: December 13, 2009, 01:34:28 PM »
I have 16 channel receiver, Would I need to get as-gr 50 gps sensor when the new upgrade takes place? Will the 16 channel be fast as the as-ga 50 gps senor?
Offline George
  • Software: Always up todate
Re: receivers
« Reply #1 on: December 13, 2009, 01:41:45 PM »
Krappie1
I am pretty sure the answer is Yes, since the GR50 is faster and more accurate then the GR16.  But, I think the bottom line is how you are using your system to determine if it is worth spending the extra money on it.
George
Offline krappie1
Re: receivers
« Reply #2 on: December 13, 2009, 01:52:15 PM »
thanks George
Re: receivers
« Reply #3 on: December 14, 2009, 10:38:17 AM »
Krappie1,
If you are asking whether the GR16 will be able to have the enhanced GPS refresh rate when the software for this is loaded onto your unit – the answer is “yes” as George so correctly surmised.  This won’t make any more accurate at positioning though.
Last post May 29, 2009, 09:07:30 PM
by panteradave
Last post May 09, 2010, 10:09:46 PM
by ROOD
Last post July 13, 2011, 03:02:43 PM
by erhan
Last post April 30, 2014, 05:54:53 PM
by Tr-196
Last post November 08, 2020, 04:42:53 PM
by danlaboucane
