Author Topic: AIS receivers compatible with humminbird  (Read 15436 times)
Offline erhan
« on: July 08, 2011, 02:23:47 PM »
Hello
Someone know which AIS receivers to use with 1197C SI ?
Best Regards
Erland
Norway
Offline Roddy
  • Scan,scan and rescan
Re: AIS receivers compatible with humminbird
« Reply #1 on: July 08, 2011, 07:06:46 PM »
erham; I have a Standrd Horizon 2100 with AIS/DSC to a HB 987 and 1198.
Any AIS/DSC radio should work. Only thing to do is hook-up HB GPS to radio and the AIS/DSC output to the HB unit.
!5mim to hook-up.
then program in AIS and DSC codes.
Enjoy and good luck!  Roddy
« Last Edit: July 12, 2011, 09:32:12 PM by Roddy »
Scan,Scan and Rescan Roddy
Offline erhan
« Reply #2 on: July 08, 2011, 09:48:49 PM »
Hi Roddy
Thank's
But how do you change the baudrate at the humminbird unit ?
Best Regards
Erland
Offline SonarTRX
    • SonarTRX
  • Unit(s): 998c-SI
  • Software: SonarTRX
« Reply #3 on: July 08, 2011, 11:23:10 PM »
According to the NMEA 0183 wikipedia article, AIS units use default baud rate of 38400:
http://en.wikipedia.org/wiki/NMEA_0183
..there is no mention of any baud rate adjustment (for AIS/RS-232) in the Humminbird manual (..for my 998c-SI)
Tore
tore@sonartrx.com
http://www.sonartrx.com
« Last Edit: July 08, 2011, 11:24:19 PM by SonarTRX »
Offline Roddy
« Reply #4 on: July 08, 2011, 11:45:43 PM »
The AIS/DSC brad rate will be listed in the AIS/DSC radio inst book
The HB 998 inst book has AIS inst on pg 132/133/134/135.
And NMEA output on pg126/130/131.
See what pops up on the drop down!
Roddy :)
« Last Edit: July 12, 2011, 01:05:14 PM by Roddy »
Offline keizerh
  • Unit(s): none
« Reply #5 on: July 10, 2011, 03:58:33 PM »
All nmea 0183 AIS receivers or class B transponders ar compatible
hendrik
« Reply #6 on: July 12, 2011, 11:51:09 AM »
There is no Baud Rate adjustment on the Humminbird units.
We have tested the AIS features using the GeoNav brand AIS system (I don’t know what the model was).
Offline erhan
« Reply #7 on: July 13, 2011, 03:02:43 PM »
Hello
I have an NASA MARINE , AIS ENGINE 2 receiver and after several attempt I suddenly get it connected with my Humminbird 1197c SI
I use the connection explained in:
http://www.humminbird.com/Faq.aspx?TaxonomyId=98A1885
The AIS are not viewed in the SYSTEM STATUS (ACCESSORY TEST)
but when the AIS receiver send data to Humminbird you can select AIS at the Accessories Menu Tab
Thank's
Erland
Norway
Last post May 29, 2009, 09:07:30 PM
by panteradave
Last post December 14, 2009, 10:38:17 AM
Last post May 09, 2010, 10:09:46 PM
by ROOD
Last post October 24, 2012, 04:58:55 PM
by wa4zfr
Last post April 30, 2013, 01:12:54 AM
Last post April 30, 2014, 05:54:53 PM
by Tr-196
Last post January 29, 2015, 02:59:11 PM
Last post November 08, 2020, 04:42:53 PM
by danlaboucane
