Author Topic: 1198 - Internal Gps  (Read 15676 times)
Offline Baker11
  • Unit(s): 1198c si
1198 - Internal Gps
« on: December 09, 2016, 08:23:29 AM »
Just purchased a 1198 SI that came with a gps puck. Was thinking of moving the puck to my back 959ci di of my tiller for direction heading at slow speeds. Question is....Does the 1198 have a internal gps to mark the odd spot from up front?
Re: 1198 - Internal Gps
« Reply #1 on: December 09, 2016, 12:00:39 PM »
I don't think so.
I think the internal GPS started with the 1199's.
« Reply #2 on: December 09, 2016, 08:25:38 PM »
ITGEEK is correct ... 1198 does not have internal GPS antenna ...
Offline Baker11
  • Unit(s): 1198c si
« Reply #3 on: December 10, 2016, 01:15:55 PM »
If i network the 959 with the 1198 could i hook up the puck to the 959 to share way points with the 1198 up front?
« Reply #4 on: December 10, 2016, 04:38:28 PM »
Yes a GPS antenna will share over Ethernet ...
Your OP indicates interest in using the puck for slow speed heading direction ...
Is the external antenna the AS GPS HS antenna or the AS GR50 that ships with the 1198 ...??
The 959 does have internal GPS ... why not connect the puck to the 1198 and let the 959 use its internal GPS antenna ... ??
« Last Edit: December 10, 2016, 04:43:34 PM by rnvinc »
Last post February 06, 2010, 11:13:18 AM
Last post September 09, 2011, 07:46:25 PM
by Jim Pauley
Last post December 04, 2010, 01:22:27 PM
by lcookie
Last post April 30, 2013, 03:52:45 PM
Last post October 08, 2013, 07:42:13 PM
by SaminVa.
Last post May 09, 2014, 11:20:35 AM
Last post July 02, 2014, 01:32:59 PM
by alexpalmer1
Last post November 08, 2020, 04:42:53 PM
by danlaboucane
