Author Topic: Helix 10 MEGA SI transducer for 300-400 feet of saltwater  (Read 7689 times)
Offline Kablars
« on: October 07, 2018, 03:29:41 AM »
Hello, i just switched from garmin to HB and realized just now that i might have made a mistake.
The unit i got is coupled with the XM 9 20 MSI T transducer.
I usually fish in fresh water 10-40 feet so that wont be a problem i guess, but once or twice per year i go offshore to fish
and then usually its 60-400 feet of depth in saltwater (80% of the time less than 120).
Is there a HB transducer that will help me achieve this or will i have to save up for an airmar transducer?
The garmin unit i had with a 500$ transducer could follow my lure down to 300 feet of water, and mark fish to 400 no problem.
Thank you.
Re: Helix 10 MEGA SI transducer for 300-400 feet of saltwater
« Reply #1 on: October 07, 2018, 10:55:56 AM »
Higher frequency imaging sonar will be challenged at deeper depths simply because higher frequencies attenuate (absorb) into water more readily than lower frequencies  ...
Common 2d sonar (83/200kHz) does operate at lower frequency than imaging sonar but may still be challenged at your target depths  ...
HB does make a SOLIX MEGA xducer with 50/200kHz 2d (XM 14 74 MSI T)
https://humminbird.johnsonoutdoors.com/accessories/transducers/xm-14-74-msi-t-20050-transom-solixonix-mega-si-mega-di-transducer?_ga=2.125763274.1538423642.1538918610-371398289.1537723667
I do not see a HELIX MEGA xducer with 50/200kHz capability on the HB website  ...
You can call HB to see if there may be future HELIX MEGA xducer with 50/200kHz capability  ...
1-800-633-1468
« Last Edit: October 07, 2018, 10:57:21 AM by rnvinc »
« Reply #2 on: October 07, 2018, 11:04:29 AM »
When you call HB you might also ask them about a Y cable Setup that possibly could use one of the 50/200kHz  2d xducers  ...
Look in your "Connected Transducer" Menu under the Sonar tab for optional xducer selections that include "50/200kHz"  ...
This will indicate which frequency combinations your unit can transmit  ...
« Last Edit: October 07, 2018, 11:06:02 AM by rnvinc »
Last post July 05, 2017, 12:05:04 AM
Last post May 08, 2017, 08:34:39 PM
by fshndude
Last post June 04, 2017, 09:08:36 PM
by Stickfish36
Last post August 15, 2017, 12:57:21 AM
by Oz306
Last post February 15, 2018, 09:11:02 PM
Last post June 16, 2018, 01:53:20 PM
Last post June 11, 2019, 10:28:35 PM
by Sodaksam
Last post September 27, 2019, 09:32:36 PM
