Author Topic: New HELIX 9 CHIRP MEGA SI GPS G2N owner / transducer location suggestions  (Read 18543 times)
Offline pdorman
  • Unit(s): 596c hd and Helix 9 mega si gen2
  • Software: not sure
  • Accessories: non
Would like suggestions as to where to install the transducer, just purchased a 4 x12 transducer mounting plate to install also.  Thanks in advance.
The mounting board already on the transom would be a good start as long as there's no rib directly in front of the xducer  ...
Offline FishinLite
  • Software: 7.765
I think the current one is a little close to the outboard. Here is the location of mine.
I currently have a SI HD transducer located in the show location. Connected to a Helix 9. I need to tilt the motor up a little but not out of the water.
I now a have a 360 mounted on the left side opposite the HD transducer.
Offline D Johnson
  • Unit(s): 2 networked Helix 10 Chirp SI GPS G2N
  • Software: 1.610
  • Accessories: B1gF1sh@HB
with the OB trimmer all the way it and turned all the way that way hold the transducer there and check that the OB won't touch it in a hard turn.  You won't have to trim out much for to see to port.  I seldom run with the ob trimmed all the way in.  Don
Don
Offline sfw1960
  • Bringer Of The 'Bird
Last post August 15, 2017, 12:57:21 AM
by Oz306
Last post February 15, 2018, 09:11:02 PM
Last post March 25, 2019, 02:01:28 PM
by RivRunR
Last post March 14, 2020, 01:34:42 AM
Last post June 06, 2020, 09:52:35 PM
Last post April 14, 2022, 10:09:49 PM
Last post April 15, 2022, 09:46:26 PM
