Author Topic: Helix 9 Mega SI G2N Transducer Rooster Tail & No Run Data  (Read 14841 times)
Offline Tbonk81
  • Unit(s): Helix 9 Mega G2N Helix 9 SI/GPS combo
  • Accessories: Network
« on: May 06, 2017, 10:28:33 PM »
I have my mega imaging ducer mounted on the right side of my transom approximately 18" from the prop. I am only getting scan data up to about 7mph and it is shooting a rooster tail about 6 feet high when i am running. I have 2004 Triton 1648 MVJ.
Re: Helix 9 Mega SI G2N Transducer Rooster Tail & No Run Data
« Reply #1 on: May 06, 2017, 11:56:51 PM »
Can you post pix of your xducer installation  ...??
Did you install the rubber plug in between the xducer "ears" that came in the xducer hardware package  ...??
« Last Edit: May 09, 2017, 10:03:52 PM by rnvinc »
Offline Tbonk81
« Reply #2 on: May 08, 2017, 10:24:20 AM »
There is no rubber mount that comes with the new mega imaging transducer. It is an all metal mount, I must say I it is not what I expected it to be.
Offline fshndude
« Reply #3 on: May 08, 2017, 08:34:39 PM »
Yes the mounting is metal but, there is a space between the plastic mounting collars. Its a little square plug that fits in between the mounting collars of the transducer. I have a Helix 9 G2N also and I had one in my package also. I have mine mounted up front on the bow so I didn't use it. However I have two transducers on the transom. I installed the plugs in both as I would shoot a rooster tail sky high even with my little 50hp.
Dave in Currituck,NC
Last post June 22, 2011, 02:25:43 PM
by Phiznat5000
Last post April 30, 2011, 09:22:30 AM
Last post May 20, 2011, 05:28:46 PM
by Roddy
Last post July 08, 2014, 10:52:19 AM
by MTBob
Last post March 23, 2014, 01:56:00 AM
Last post October 13, 2014, 10:26:07 PM
by xSilmarilSx
Last post April 20, 2016, 10:04:42 PM
Last post September 02, 2016, 08:45:33 AM
