Author Topic: Helix 10 Si G2n Mega transducer location  (Read 10407 times)
Offline soopd
  • Unit(s): 798c
« on: February 15, 2018, 12:15:12 PM »
I am trying to install a Helix 10 Si G2n Mega transducer on an aluminum SeaArk ZX180. I thought about installing the transducer above the drain plug in front of the lower unit if I have enough clearance. I know I will not get on plane readings, however, I will address that with another transducer where I have one installed now.   Will the drain plug effect my si or my di readings?  Is this a good location?  Any better solutions?
Attached are some pictures of a zx180 that looks like mine. It is not my boat, but my hull is the same hull.
Re: Helix 10 Si G2n Mega transducer location
« Reply #1 on: February 15, 2018, 09:11:02 PM »
The MEGA xducer will work for slow speed scanning above the drain plug  ... This is a similar location to a jackplate mount  ...
You may pick up the additional 2d xducer housing in the right SI  ... It would show as a hard echo line parallel, and to the right of the center line in the SI image  ...
Last post April 04, 2016, 10:15:28 PM
Last post July 05, 2017, 12:05:04 AM
Last post May 08, 2017, 08:34:39 PM
by fshndude
Last post June 04, 2017, 09:08:36 PM
by Stickfish36
Last post August 15, 2017, 12:57:21 AM
by Oz306
Last post February 19, 2018, 08:24:42 PM
by Whistler
Last post June 16, 2018, 01:53:20 PM
Last post September 16, 2018, 03:15:09 AM
by cade
