Author Topic: ALL SI Models - GPS offset  (Read 9585 times)
Offline October1
  • Unit(s): Getting ready to buy
  • Software: N/A
  • Accessories: None
« on: April 01, 2018, 04:11:02 PM »
Model:
ALL SI Models
Suggested Upgrade:
GPS offset
Explanation:
It would be nice to have an option to set the GPS distance between the head unit and the transducer to get more accurate positioning. This function would only be engaged while moving (such as while using AutoChart Live for ex) so as not to introduce inaccuracies.
For example, if my console is 12' from my transducer I could go in and manually set the offset to 12' to the south while moving north. From that point on when I'm moving north any mapping points or way points would show up 12' to the south of the head unit where the transducer is for greater accuracy. If I was moving east then any mapping points or way points would show up 12' to the west, etc.
This could be an automatic feature that would only happen while moving in any given direction such as under power or drifting with the wind so that the unit wouldn't get confused on which direction it is facing and therefore accidentally create inaccuracies. Or this could simply be a purely manual only function that you have to turn on and off each time you want to use it.
Added in Software Version:
Comments on Update:
Offline jimf
  • Unit(s): 997ci si
Re: ALL SI Models - GPS offset
« Reply #1 on: September 07, 2018, 11:15:17 AM »
just buy a exteral GPS plug and mount in front or in back near transducer. easy fix
Last post November 01, 2009, 02:41:11 AM
Last post March 03, 2011, 06:43:47 AM
by stillbear
Last post February 06, 2012, 06:28:07 PM
by stillbear
Last post April 04, 2017, 06:34:25 AM
by LGF
Last post April 09, 2014, 06:47:11 AM
by bobcoy
Last post July 01, 2014, 06:25:06 PM
Offset Speed
Started by Fay 798c SI
Last post October 25, 2014, 08:53:41 AM
by Fay
Last post August 28, 2017, 10:01:22 PM
