Author Topic: 898 voltage offset  (Read 11217 times)
Offline tambrose76
  • USMC Ret.
  • Unit(s): 898c, 737, WIDE ONE, SUPERTRAP30, PORTAB
  • Software: ALWAYS UPDATED
  • Accessories: GPS16 WXSENSE
898 voltage offset
« on: August 26, 2017, 04:32:39 PM »
Using a calibrated voltmeter, the feed to my 898 reads 1.6vdc higher than what the HB display says.  This reveals my main battery to maintain 12.2vdc after an 8hr rest and no other electronics to bleed it down. New battery, Guest algorithm charger on AGM setting, wiring intact, electronics technician. Why would the display read lower than the input voltage. Also, I see the Low Voltage alarm comes on during engine start, noting the current draw and resultant voltage drop to bark.  Why not a measurement of the last ten seconds (averaged) to preclude alarming but for the display voltage during fishing use?
"Some men see things as they are and say why.
I dream things that never were and say why not." --George Bernard Shaw
Re: 898 voltage offset
« Reply #1 on: August 26, 2017, 09:11:06 PM »
How are you checking the voltage ..... If you remove the cable collector on the 898 there are pins on the power cable that can be accessed from outside the connector.  Check the voltage there with the unit powered on.
There is no calibration for the voltage reading.
Offline tambrose76
  • USMC Ret.
« Reply #2 on: August 28, 2017, 04:16:17 PM »
The voltage at the pins, battery, bus bar are identically high compared to the display.
Offline Gimp
  • Unit(s): 998 HD SI
  • Accessories: i-Pilot Link
« Reply #3 on: August 28, 2017, 04:47:10 PM »
The problem is you need to measure the voltage at the pins WHILE the battery is under load (i.e. while the unit and everything else that is connected to the battery is ON) The hard part is getting the volt meter onto the pins while the unit is on.
A battery under load will read lower that at idle. The more 'worn out' the battery is, the more the two measurements will differ.
« Reply #4 on: August 28, 2017, 10:01:22 PM »
Turn the backlight the down to 1 and the readout voltage will be closer to your volt meter reading  ...
Last post November 01, 2009, 02:41:11 AM
Last post March 03, 2011, 06:43:47 AM
by stillbear
Last post February 06, 2012, 06:28:07 PM
by stillbear
Last post April 04, 2017, 06:34:25 AM
by LGF
Last post October 11, 2013, 06:43:25 PM
by slabbacks
Last post April 09, 2014, 06:47:11 AM
by bobcoy
Last post July 01, 2014, 06:25:06 PM
Offset Speed
Started by Fay 798c SI
Last post October 25, 2014, 08:53:41 AM
by Fay
