Author Topic: Keel offset  (Read 11190 times)
Offline Meena
  • Unit(s): 798
Keel offset
« on: April 02, 2014, 05:55:53 PM »
This is probably obvious but how can I adjust the difference in the depth of my transducer with the actual water surface?
Re: Keel offset
« Reply #1 on: April 03, 2014, 03:07:11 AM »
The "Depth Offset" menu is in the Main tabbed menu system under the Setup tab...
Press Menu twice to get into the Main tabbed menu...
Cursor over to the Setup tab...
Cursor down to "Depth offset"...
Cursor a positive number to read a depth from the waterline...
Cursor a negative number to read a depth from the keel...
Re: Keel offset
« Reply #2 on: April 03, 2014, 11:18:50 AM »
FYI: In some of the really old units (Matrix) that menu used to be called “Keel Offset”.
Offline Meena
  • Unit(s): 798
Re: Keel offset
« Reply #3 on: April 03, 2014, 06:23:21 PM »
Thanks for the help. I will adjust that next time out.
Offline Meena
  • Unit(s): 798
Re: Keel offset
« Reply #4 on: April 08, 2014, 05:36:08 PM »
Ok I went to this screen but depth offset is not on option. This is a new 798ci HD also.
edit--- Never mind I had the sonar turned off.
« Last Edit: April 08, 2014, 05:39:59 PM by Meena »
Offline bobcoy
  • Unit(s): 1197 & 1198
  • Software: 6.640 & 7.670
Re: Keel offset
« Reply #5 on: April 09, 2014, 06:47:11 AM »
Make sure you user mode is "advanced" or you can't see that option.
Last post November 01, 2009, 02:41:11 AM
Last post March 03, 2011, 06:43:47 AM
by stillbear
Last post February 06, 2012, 06:28:07 PM
by stillbear
Last post December 27, 2012, 10:03:42 AM
Last post April 04, 2017, 06:34:25 AM
by LGF
Last post October 11, 2013, 06:43:25 PM
by slabbacks
Last post May 05, 2014, 04:07:57 PM
Last post July 01, 2014, 06:25:06 PM
