Author Topic: How to set the map offset  (Read 8333 times)
Offline TazzMan
  • Unit(s): 788 CI, 565, 898si c
  • Accessories: Quadbeam transducer
« on: March 02, 2011, 06:41:46 AM »
I have tried to to use the map offset.  I know there is a way to set the depth offset.  If the lake water is lower or higher than when the map was made then the depth lines on the map are not correct. I set my unit to highlight 20ft and the water is only 16ft.  I have a navonics card for my area.   I set the offset like it says but noght seems to change and the depth lines same the same.  maybe I am doing something wrong.   please advise!!!
Next time you think you are perfect try walking on water
Re: How to set the map offset
« Reply #1 on: March 02, 2011, 02:58:28 PM »
Tazzman,
I think that is only available for the Lakemaster Charts.
http://forums.sideimagingsoft.com/index.php?topic=1190.0
Offline stillbear
  • Stillbear
  • Software: 5.840 5.700- 4.0
« Reply #2 on: March 03, 2011, 06:43:47 AM »
Tazzman I think you are talking about shaded depth that is what Navionics at this time has.
Lake Master has water offset it is exclusively made for HB. I use both.
Last post February 06, 2012, 06:28:07 PM
by stillbear
Last post April 04, 2017, 06:34:25 AM
by LGF
Last post October 11, 2013, 06:43:25 PM
by slabbacks
Last post April 09, 2014, 06:47:11 AM
by bobcoy
Last post July 01, 2014, 06:25:06 PM
Offset Speed
Started by Fay 798c SI
Last post October 25, 2014, 08:53:41 AM
by Fay
Last post August 28, 2017, 10:01:22 PM
Last post September 07, 2018, 11:15:17 AM
by jimf
