Author Topic: copying zeroline card  (Read 12727 times)
Offline danlaboucane
  • Unit(s): ,798 hd onix8 ct , solix 12 msi
  • Software: 7.6 ,3.03
  • Accessories: sm3000+eth 5 port to get SI on onix CT,
« on: June 21, 2017, 09:35:51 AM »
hello guys new to this mapping and spent a day on the water and filled up the memory on the onix so i need a card ! question is :can i copy a zeroline card to an other card to use in a 700 series unit ? i have two in the boat that would be used mostly as  mapping . and for now if only can copy from zeroline to zeroline i would get just a card for now to record and get autochart pro later .
Re: copying zeroline card
« Reply #1 on: June 21, 2017, 02:47:36 PM »
The 700 series isn't compatible with Autochart Live ..... You would have to use the Autochart PC software to make a map card for them.
Since you get a ZLC with the software, the cost of the software isn't that much more than buying a ZLC.
« Reply #2 on: June 21, 2017, 04:50:51 PM »
thanks bob ,and that could be done with the map i will record with the zeroline ? or i have to rely on other maps ?
« Reply #3 on: June 21, 2017, 05:06:08 PM »
I don't have a unit with Autochart Live, so can't help you with specifics.   I'd recommend getting the Lake Images training set to save you some time and mistakes using the Autochart PC software.
« Reply #4 on: June 21, 2017, 07:22:38 PM »
ok thanks :)
« Reply #5 on: June 22, 2017, 08:27:11 AM »
i did order the dvds ,will see ! ;)
by slabbandit
Last post July 11, 2014, 06:11:00 AM
by mmikos
Last post July 08, 2015, 10:58:40 AM
Last post May 04, 2016, 09:48:33 AM
by N9Phil
Last post July 04, 2016, 11:04:13 PM
by JiMinneye
Last post July 06, 2016, 08:57:45 AM
by Martins
Last post June 22, 2017, 09:34:34 PM
by papasage
Last post February 20, 2019, 10:34:24 AM
by rbdavis3591
