Author Topic: island on my zeroline card that does not exist  (Read 11624 times)
Offline mmikos
  • Unit(s): 899ci HD
  • Software: 7.2
  • Accessories: autochart pro, ipilot
« on: July 10, 2014, 08:42:21 AM »
I am trying to map my local lake.  The humminbird world map shows my lake without an island in the center of it.  when i use the data from the lkmaster zeroline card an island appears, where none exists.  I have tried to clear this island from the map using the clear area command but this has no lasting effect on the data other than destroying my imported data.  Any ideas on how to delete this non-existent island??
Offline D S
  • Software: 7.5
Re: island on my zeroline card that does not exist
« Reply #1 on: July 10, 2014, 11:53:02 AM »
i had similar problem with error on background shoreline  that i drew then imported as the lakemaster shoreline was innacurate
...called support,,
   and i ended up deleting the AC file  from the zerolines card and starting all over with new data/map on zerolines card
from what i can see u can edit data on the pc with in the program but once its written to the card i dont think u can edit it??
perhaps greg or somenone else can chime in with comments
DS
stgr
Offline mmikos
  • Unit(s): 899ci HD
  • Software: 7.2
« Reply #2 on: July 10, 2014, 04:20:07 PM »
dave thanks for the response.  the island came into my pc from the zeroline card before any mapping was done...i.e. before a ac folder was created
Offline D S
  • Software: 7.5
« Reply #3 on: July 10, 2014, 05:06:45 PM »
looks like this is another case of an inacurate background for the shoreline....you could draw your own on GE and then import to the autocharts ,as i did because of the inacuracies...
see the tutorial in the  AC software ..not that difficult i think i just imported a KML
DS
stgr
Offline mmikos
  • Unit(s): 899ci HD
  • Software: 7.2
« Reply #4 on: July 11, 2014, 06:11:00 AM »
Dave
thanks again for the response.  I will give it a try this weekend
Last post August 27, 2010, 03:24:35 AM
by gobio
Last post January 17, 2010, 03:38:55 AM
by ukmailserver
Last post June 01, 2011, 05:09:00 PM
by slabbandit
Last post May 04, 2016, 09:48:33 AM
by N9Phil
Last post July 06, 2016, 08:57:45 AM
by Martins
Last post June 22, 2017, 08:27:11 AM
by danlaboucane
Last post February 20, 2019, 10:34:24 AM
by rbdavis3591
