Author Topic: Zeroline Card not recognized  (Read 14482 times)
Offline emerles
  • Unit(s): Helix 7 / Helix 10
  • Software: latest
  • Accessories: 360 Mega
« on: February 18, 2019, 10:27:29 AM »
After installing autochart on my new desktop PC the zeroline card was not recognized any longer.
I am not able to create a background map anylonger.
Is there a way to check, if the card is damaged?
Re: Zeroline Card not recognized
« Reply #1 on: February 18, 2019, 08:49:50 PM »
Here is contact you info if no one answers  ...
https://www.johnsonoutdoors.com/locations?id=127
Offline rbdavis3591
  • Unit(s): Helix 9 SI
  • Software: Unknown
  • Accessories: None
« Reply #2 on: February 19, 2019, 06:52:25 AM »
I know this type of problem has been discussed before but perhaps a picture would help get responses.
These are the steps I took when I had a problem with the background map not working correctly.
If you do these steps I would recommend first skipping step #3 to see if that resolves the problem.
1. Uninstall AutoChart Pro.
2. Delete the directory where AutoChart Pro was installed.
3. Went into the Windows Registry Editor (not recommended for the faint of heart or unknowledgeable).
    I did not use a finesse approach but rather did a more drastic action of searching and deleting any and all keys that had AutoChart in them.
    Doing this has appeared to have not caused any problems but YMMV if you try this same approach.
4. Closed all running programs and rebooted computer.
5. Reinstalled AutoChart Pro including the activation key.
Offline emerles
  • Software: latest
« Reply #3 on: February 19, 2019, 01:46:44 PM »
Thanks alot.
Offline emerles
  • Software: latest
« Reply #4 on: February 19, 2019, 02:17:34 PM »
Thanks alot, it is working now.
Offline rbdavis3591
  • Software: Unknown
  • Accessories: None
« Reply #5 on: February 19, 2019, 04:26:14 PM »
In case someone else has the same problem what solution worked for you?
Offline emerles
  • Software: latest
« Reply #6 on: February 20, 2019, 07:29:20 AM »
I performed Point 1, 2, 4 and 5, but skipped Point 3.
Offline rbdavis3591
  • Software: Unknown
  • Accessories: None
« Reply #7 on: February 20, 2019, 10:34:24 AM »
I will keep that in mind if I give someone else advise. I was not sure if step #3 was necessary but I wanted to remove all aspects after weeks of no resolution.
Last post March 22, 2010, 10:23:29 PM
Last post April 22, 2010, 09:24:45 AM
Last post March 26, 2014, 10:46:04 PM
by reelnmn
Last post July 11, 2014, 06:11:00 AM
by mmikos
Last post August 29, 2015, 11:00:48 AM
by hatchetman
Last post May 04, 2016, 09:48:33 AM
by N9Phil
Last post July 06, 2016, 08:57:45 AM
by Martins
Last post June 22, 2017, 08:27:11 AM
by danlaboucane
