Author Topic: Need Help Selecting SD card and Mapping card for 998  (Read 13303 times)
Offline slabbandit
« on: August 15, 2012, 03:15:19 AM »
 Going to help a friend install a 998 SI on his boat. What size SD card do you guys recommend and what Map card is good to use for Arkansas lakes? Should we wait for the Lakemaster maps to come out for our area?
Offline Roddy
  • Scan,scan and rescan
Re: Need Help Selecting SD card and Mapping card for 998
« Reply #1 on: August 15, 2012, 11:25:29 AM »
slabbandit, A SD Card of 4G works just fine.
Navioncs Lake Master Cards and Fishing Hot Spots Cards check the Nanioncs home page.
Some people are using Dr.Deapth or SONAR.TRX to build there own SI botton charts.
I'am very happy with SONAR.TRX!
Roddy
Scan,Scan and Rescan Roddy
Offline George
  • Software: Always up todate
« Reply #2 on: August 15, 2012, 07:37:49 PM »
slabbandit
A 4 or 8 GB SD card is probably all you will need, I also purchased the smallest card I could find, this I use only for making updates to my units.
As far as a navigation cards, Navionics covers everything across the the U.S., Lake Master is expanding so depending on where you live, will determine if you can use a LakeMaster card.
I have both cards and they both have some unique issues both pro and con.  You will need to look at what both cards have for the areas you fish. One may have High Definition lakes that you use while the other may not, so be careful before you make your purchase.
George
Offline staoB regnaR
  • Unit(s): 998,788
  • Software: 6.18, 6.25
  • Accessories: GPS reciever
« Reply #3 on: August 15, 2012, 09:10:34 PM »
I use a 8GB Sandisk, it is only 8GB instead of 4 because they were on sale for cheaper than 4GBs. I use Navionics (Southern), but I may get lakemaster next time.
Ranger Boats, Strike King, Berkley, St. Croix, Quantum, Omega, Wired2Fish.
Offline slabbandit
« Reply #4 on: August 15, 2012, 10:25:17 PM »
 Thanks for the advice. I'll pick up an 8 GB card tomorrow and we'll probably wait and see what Lakemaster comes out with for Arkansas.
Last post May 13, 2010, 02:24:47 PM
Last post April 08, 2011, 02:09:09 PM
Last post January 16, 2012, 02:11:09 PM
Last post June 20, 2017, 09:47:50 PM
Last post June 14, 2012, 11:02:31 AM
Last post March 21, 2014, 11:54:47 AM
Last post July 04, 2016, 11:04:13 PM
by JiMinneye
Last post July 26, 2017, 12:52:40 PM
by Mark Saikaley
