Author Topic: Can i network 998c to Helix 7 Chirp Gps G2N and Min Kota Ultrra.  (Read 18519 times)
Offline fishhook
  • Unit(s): 998c si Helix 9 Chrip Gps G2n
  • Accessories: Ultra I-Piolt-Link
Can i network 998c to Helix 7 Chirp Gps G2N and Min Kota Ultrra. And what would i need.
Re: Can i network 998c to Helix 7 Chirp Gps G2N and Min Kota Ultrra.
« Reply #1 on: April 19, 2017, 09:40:25 PM »
You will need the AS ETH 5PXG
http://www.humminbird.com/Products/AS-ETH-5PXG/
You will need the AS EC QDE adapter cable for the HELIX  ... (998 doesn't need the adapter cable)  ...
http://www.humminbird.com/Products/AS-EC-QDE/
And you will need an Ethernet cable from each unit to the AS ETH 5PXG  ... And an Ethernet cable from the Ulterra (if the Ulterra is iLink capable) to the AS ETH 5PXG  ...
The AS ETH 5PXG requires 12v power so plan it's installation  ...  and power it thru a switch so it doesn't drain your battery when not in use  ...
« Last Edit: April 19, 2017, 09:42:44 PM by rnvinc »
Offline fishhook
« Reply #2 on: April 20, 2017, 03:33:47 PM »
thanks revinc, with the  AS ETH 5PXG could I add a heading course to ?
« Reply #3 on: April 20, 2017, 10:00:11 PM »
Ethernet is not necessary for the AS GPS HS antenna  ...
It will connect directly to 1 of the head units  ...and can then be shared thru Ethernet  ...
Last post November 17, 2013, 09:15:46 AM
by bemof
Last post November 18, 2013, 12:29:40 PM
Last post November 01, 2015, 11:10:32 PM
Last post January 24, 2016, 09:38:56 PM
Last post March 12, 2016, 10:08:59 AM
by cramar_2112
Last post October 15, 2016, 01:31:44 PM
by scottn
Last post November 06, 2016, 08:03:57 AM
Last post April 15, 2020, 09:51:39 AM
by bglures
