Author Topic: Can I network my 1197 with 998c SI CBO?  (Read 9854 times)
Offline knorstu
  • I work therefore I fish!
  • Unit(s): 1197C SI
  • Software: 5.840
  • Accessories: none
« on: November 15, 2013, 10:14:20 PM »
Hi. I'm finding a good deal on a 2012 998c SI CBO unit. I would like to ethernet connect it to my 1197 so my wife has a display too. When we troll, I block her view.
Will these units direct connect to each other using an ethernet cable?
What does the CBO mean? Is it just a combination of unit and preloaded maps?
I'm also looking to mount the 998 in the bow when I'm on the trolling motor again connecting to the 1197. Any reason I can't if I swap cables at the 1197 when I move the 998?
Any other suggestions?
Thanks for any and all help!!!
Kevin
Offline LocDown
    • Fishing Videos
  • Unit(s): 1199 H12G2N-HW-MSI
Re: Can I network my 1197 with 998c SI CBO?
« Reply #1 on: November 16, 2013, 01:37:46 PM »
CBO is combo unit, pretty much complete. CHO is display only.
And I don't think the 1197 is ethernet capable. It is interlink capable.
« Reply #2 on: November 16, 2013, 05:55:28 PM »
Yes,the 1197 does have Ethernet!  You shouldn't have any problems.
« Reply #3 on: November 18, 2013, 12:29:40 PM »
I’m thinking that the “CBO” was a typo for “CHO” (the “B” key is close to the “H” key on your keyboard).  That is a Control Head Only unit and it will not come with a transducer.
Yes the 1197 is Ethernet capable as Robert stated.
If I am understanding you correctly you are going to set up two locations on your boat to use the new 998 unit from, correct?  If so, you will need to buy a second power cable and possibly a GPS Receiver, unit gimbal mount and connector collector – all depending on how you do this.  You will definitely need an Ethernet Connection Cable (or cables) in the appropriate length(s).
Last post August 02, 2011, 09:05:07 AM
Last post January 27, 2013, 09:27:17 AM
by Jim Jack
Last post February 21, 2013, 10:37:19 AM
by fasteddiemd
Last post April 08, 2013, 10:27:53 AM
Last post July 12, 2013, 09:07:35 PM
by tgordon
Last post December 30, 2013, 08:47:55 PM
by Rotus623
Last post May 05, 2014, 04:22:43 PM
Last post April 20, 2017, 10:00:11 PM
