Author Topic: Helix 5 and Chirp Question  (Read 12475 times)
Offline cramar_2112
  • Unit(s): PiranhaMAX 143 and PiranhaMAX 170
  • Software: unsure, boat stored
  • Accessories: I don't have any installed
« on: March 11, 2016, 04:06:00 PM »
Hi, I'm looking at the Helix 5 and noticed that for a bit more money I can get a competitors unit that has Chirp.
With all the different model combinations and terms it gets a bit confusing on what each unit has or is missing, just wondering if the lack of Chirp in the Helix 5 is a big deal or not.
Also, wondering if Chirp and Dual Beam + are essentially the same thing.
I fish freshwater and typically less than 50 feet.
« Last Edit: March 11, 2016, 04:27:15 PM by cramar_2112 »
Re: Helix 5 and Chirp Question
« Reply #1 on: March 11, 2016, 11:18:47 PM »
Dual Beam is HB's moniker for 2d that is capable of 2 separate fixed frequencies ...
CHIRP is a Sonar technology that sweeps a broad range of frequencies at the same time ... This has the potential to allow much more data to be returned and processed by the CHIRP processor ...
There are many levels of CHIRP ...depending on the equipment used ... And price goes up as the equipment quality goes up ...
Most of the lower and mid priced CHIRP is indeed still transmitting a sweep frequency range ...but transmitting that signal thru regular stock xducers that are designed for fixed frequency pulse ...
The higher priced CHIRP is also transmitting a sweep frequency signal ...but transmitting that signal thru very expensive xducers designed specifically for a CHIRP system ...
There is advantage in increased target separation and cleaner images in the lower and mid priced CHIRP ...but it may not be as much of a difference that one could discern ...
Offline cramar_2112
« Reply #2 on: March 12, 2016, 10:08:59 AM »
Thanks for that info!
Last post November 01, 2015, 11:10:32 PM
Last post January 24, 2016, 09:38:56 PM
Last post March 11, 2016, 03:08:50 AM
by Superterrorizer
Last post October 17, 2016, 08:28:48 AM
Last post April 03, 2019, 11:27:28 AM
Last post October 27, 2019, 04:49:01 AM
by reso
Last post February 27, 2020, 09:50:10 AM
by JDM70
