Author Topic: Depth fluctuating  (Read 7796 times)
Offline coldsteel
  • Unit(s): 798ci si combo
Depth fluctuating
« on: July 19, 2016, 10:36:34 PM »
I have a 999 unit and the last two times out when I knew I was in 25 ft. Of water, it would jump to 40+ and stay that way for some time and the go back to actual depth for a few minutes and then back to  40 something ft. Any ideas why depth reading fluctuates?
Re: Depth fluctuating
« Reply #1 on: July 20, 2016, 01:18:58 AM »
A few things to check ... :
*xducer level with the water's surface ... ??
*xducer clean with no algae or scum covering the face of the xducer ... ??
*current software ... ??
Another possibility is a very hard bottom creating a double echo of the sound pulse reflecting off the water's surface and making a 2nd trip to the bottom ...
Switchfire Clear and reduce Sensitivity can help in this scenario ...
Offline coldsteel
« Reply #2 on: July 20, 2016, 02:17:43 PM »
Transducer is level.  Transducer is clean, Has the latest software. I fish this area often and never had this issue before. Just stared last two outings. Very puzzled. Other than depth reading it seems to be in working order.
« Reply #3 on: July 20, 2016, 11:52:40 PM »
You might try Restore Defaults ... These little computers need a restart from factory settings occasionally ...
If the issue persists, or seems to occur more frequently - try to capture a screenshot and post it here ...
Offline coldsteel
« Reply #4 on: July 21, 2016, 08:13:39 PM »
I will try that, Thanks for tips
« Reply #5 on: July 22, 2016, 12:14:39 PM »
Two other things to consider:
 1) Interference:  Try it with every other electrical device off, and see if the depth changes.
 2) Battery going bad.  Charge it up and have it load tested.  It doesn't matter if it's new, or you KNOW it's good.
A brand new battery could have sat on the shelves, discharged for months.
Offline coldsteel
« Reply #6 on: July 22, 2016, 02:50:04 PM »
I've been thinking about the battery, it is 3 years old. The voltage on the humminbird screen starts out art about 12.6 volts. It used to stay in that area all day, but now drops off quickly to about 11.8 volts when motor is not running. Like when anchored, drifting or trolling. It comes back up when motor is running. I assumed it was still enough volts to power unit. I was thinking anything over 10 volts volts would be ok.
« Reply #7 on: July 22, 2016, 02:55:33 PM »
It may have enough volts, but may not be able to sustain it.
I had a battery once, that charged up to 12.6 volts, but would not allow the unit to boot up.
You should test your battery.
Offline coldsteel
« Reply #8 on: July 22, 2016, 04:36:33 PM »
I will have it checked and let you know what I find out.
Last post March 29, 2010, 01:17:11 PM
Last post April 06, 2010, 03:38:06 PM
by Chiboo
Last post June 23, 2010, 09:24:55 PM
by reelman
Last post June 11, 2010, 08:42:41 PM
by majflyboy
Last post April 22, 2011, 11:04:47 AM
by Roddy
Last post July 17, 2012, 04:00:54 AM
by Rüdiger
Last post October 25, 2014, 02:56:14 PM
by DiveExplorer
Last post December 13, 2014, 09:51:59 AM
by AnglerDon
