Author Topic: 597 hd di / Dr Depth  (Read 9350 times)
Offline Clarkey1972
  • Unit(s): 597 DI
« on: July 15, 2012, 01:04:59 PM »
Hi
Im confused !
Can I use Dr Depth software to build maps from tracks saved on the unit including depth information?
The Dr Depth website says it can only be done from series 7 upwards, but it also says you can only make maps for lowrance units and from reading info on this site it obviously caters for humminbird users also.
Any help appreciated.
Rich
Offline xSilmarilSx
  • Software: 6.250 - 5.320
Re: 597 hd di / Dr Depth
« Reply #1 on: July 15, 2012, 06:08:55 PM »
If you have a SD card slot and can record your data on it you should be fine.
Offline Clarkey1972
  • Unit(s): 597 DI
« Reply #2 on: July 16, 2012, 03:43:09 AM »
thanks for the reply.
Yes I have an SD card.
Does anyone know which files do what.....ie
.dat
.idx
.son
Many thanks
Rich
Offline Rüdiger
« Reply #3 on: July 16, 2012, 04:03:17 AM »
Hi Rich
You must import and convert the .son files.
mvh
Rüdiger
Finding is better than losing
Offline Clarkey1972
  • Unit(s): 597 DI
« Reply #4 on: July 16, 2012, 04:22:50 AM »
Many thanks Rüdiger
When you say import them do you mean import them into Dr Depth or some other software first?  If so whats the other software?
Thanks again
Rich
Offline Rüdiger
« Reply #5 on: July 17, 2012, 04:00:54 AM »
Hi Rich
When you start DrDepth you get the option File Import/Convert, use this.
mvh
Rüdiger
Last post April 22, 2011, 11:04:47 AM
by Roddy
Last post May 30, 2013, 04:11:34 AM
by yvautrin
Last post September 10, 2013, 12:13:54 PM
Last post April 04, 2014, 11:34:17 PM
Last post April 27, 2014, 08:10:49 PM
by Gaylan
Last post June 05, 2014, 08:46:19 AM
Last post January 18, 2015, 06:43:36 PM
by dan8965
Last post July 09, 2015, 11:24:06 AM
by Carver
