Author Topic: Renaming tracks  (Read 13599 times)
Offline afaust
  • Unit(s): Helix 5 SI GPS KVD
  • Software: 7.78
  • Accessories: 32GB micro SD
Renaming tracks
« on: June 12, 2016, 05:06:37 PM »
When getting the info from my sad card, I want to keep the info organized, but still want to keep the info on the card for now. Can I rename the files and directories, and if so, are there specific rules to ensure no issues? I.e. One track is 000001 with a directory named like this as well as other files with the same name. Can I change the directory name? Can I change the file names as well with something more logical for my mapping and planning?
Allan
Online rnvinc
Re: Renaming tracks
« Reply #1 on: June 13, 2016, 01:54:31 AM »
I found this info (I don't use saved Tracks myself so I have no experience in your query) ...
http://forums.sideimagingsoft.com/index.php?topic=6748.0
Offline afaust
  • Software: 7.78
Re: Renaming tracks
« Reply #2 on: June 13, 2016, 12:01:22 PM »
Thx Rickie,
I had a quick look and I had used Humviewer to export the files to Google Earch, and I was able to see tracks in GE. I didnt realize humminbird PC could do something similar. I will be looking into it this week. Thx again.
Offline afaust
  • Software: 7.78
Re: Renaming tracks
« Reply #3 on: June 13, 2016, 05:36:30 PM »
when i load humminbirdpc, it tells me there are no waypoints,tracks or routes.... but i know there are tracks.... i just dont know how to see them...
Offline tschultz
Re: Renaming tracks
« Reply #4 on: June 14, 2016, 09:03:14 AM »
Is your file type set on gpx rather than humminbird when trying to see/import?
Also you cannot rename those tracks i.e. 00003.ht on the sd card itself. You must open them in hbirdPC then you can rename the tracks/waypoints to your hearts content, and save them to your computer or back to the SD card. Note they will still show up as 00003.ht when you save or export them within the matrix file itself on the sd card. The actual names are contained within. Don't know if that makes sense or not.
Offline afaust
  • Software: 7.78
Re: Renaming tracks
« Reply #5 on: June 14, 2016, 08:24:42 PM »
I tried changing the file type to humminbird as well, under file open, files of type hummingbird, and the software doesn't see anything on the card at all, even though the folders and files are all there when looking in windows explorer.
Yes the file naming makes sense in that the unit uses the 00003.ht for its own use, and you'd see your renamed info on the screen when selecting it.... Thx for that info...
Allan
Offline Beaulieu80
  • Unit(s): 798CXI HD SI COMBO
  • Software: 7.68
Re: Renaming tracks
« Reply #6 on: July 19, 2016, 11:09:08 AM »
I suggest you to use an APP to merge your HT files so you can maximize them on each one of the so you get a maximum 21800K of tracks points inside.
Here are the steps I do to maximize them so we have less files to backup and manage.
1) Open the HT file with Humminbird PC
      -this will create a GPX file for each HT file you select
2) Use the attach program on this thread that I have made of to merge on disired quantity of tracks
enjoy
Offline afaust
  • Software: 7.78
Re: Renaming tracks
« Reply #7 on: July 28, 2016, 05:14:21 PM »
thx, ill be trying it out...
Offline afaust
  • Software: 7.78
Re: Renaming tracks
« Reply #8 on: July 28, 2016, 05:21:03 PM »
I dont understand. it seems that the files are dat files and not ht files. is there something im doing wrong?
Last post August 15, 2010, 10:30:48 AM
by Wayne P.
Last post April 24, 2012, 08:45:14 AM
Last post June 19, 2012, 10:24:38 AM
by bassin101
Last post August 14, 2012, 04:45:50 PM
by Northwoods
Last post October 01, 2012, 02:16:41 PM
Last post March 09, 2013, 09:45:28 PM
Last post June 24, 2013, 08:29:17 AM
by LittleGazoo
Last post March 15, 2014, 01:08:21 PM
