Author Topic: renaming waypoints  (Read 8097 times)
Offline bassin101
  • Unit(s): 1
renaming waypoints
« on: June 19, 2012, 08:10:33 AM »
Hey Guys,
New to the forum and in need of some pointers. Just got the Humminbird 798ci HD SI Combo and everything seems to going good but I can't figure out how to rename the waypoints. Do I need to connect the unit to my PC? Any help would be greatly appreciated. Thanks
Re: renaming waypoints
« Reply #1 on: June 19, 2012, 09:32:28 AM »
There are three ways to go about doing this:
1.) You can rename them in the unit itself by going into the waypoint menu and use the Edit function to rename them.  Depending on what software you have in your 798ci HD Si will depend on where it is.
2.) Export your waypoint data to an SD/SDHC memory card and upload it to HumminbirdPC and rename them there.  I like this option better if you have more than a few waypoints that you want to change the names for.
3.) You can buy/make the Humminbird PC Connect cables and import the waypoints from your 798ci HD Si unit into HumminbirdPC and rename them that way as well.
#1 is the cheapest way to go about this.
#2 is the most reasonable IMHO as all that is involved is the cost of the SD/SDHC memory card.
I would only use #3 if I already had the PC Connect cables or if I was planning on buying them for another reason.  I have a set of these in my office but usually still use an SD memory card.
Offline bassin101
  • Unit(s): 1
« Reply #2 on: June 19, 2012, 10:24:38 AM »
Thanks Greg. You da man.
Waypoints
Started by Rev 798c SI
Last post March 06, 2011, 06:38:31 PM
by Ddorriety
Last post March 09, 2011, 07:49:30 PM
by Hollywood
Last post May 13, 2011, 11:35:52 AM
Last post January 19, 2012, 01:04:19 PM
Last post May 09, 2012, 03:45:57 PM
by Sigler
Last post March 15, 2014, 01:08:21 PM
Last post July 28, 2016, 05:21:03 PM
by afaust
