Author Topic: user tracks  (Read 18011 times)
Offline mulliemark
user tracks
« on: June 27, 2012, 05:42:55 PM »
I am sorry if this has been asked before , but I was wondering how to transfer user tracks created in humviewer  to my unit?
thnx
mark
Offline mulliemark
Re: user tracks
« Reply #1 on: June 27, 2012, 10:27:15 PM »
no humviewers out there?
Offline newkid4si
  • Unit(s): 998c si
  • Software: v 5.70
Re: user tracks
« Reply #2 on: June 28, 2012, 12:24:20 AM »
mulliemark
      I don't know the answer, but someone will help you, probably tomorrow.
      It might help if you post which unit you have as the software varies between units.
               mike
Offline mulliemark
Re: user tracks
« Reply #3 on: June 28, 2012, 07:45:22 AM »
I have a 798
Offline Weekend Warrior
  • Unit(s): 898C SI
  • Software: 6.180
Re: user tracks
« Reply #4 on: June 28, 2012, 12:44:10 PM »
I have an 898 and I JUST figured out how to do this the other day.  I will try to help.  After you've created your user track(mine happened to be 8 points along an underwater hump), you export just the user track to where you want your HBPC files to reside as a .gpx file. Once you have it there(in HBPC), you just upload the user track .gpx file to the drive your SD card is in.  Then, IMPORTANT!, power your unit on first and into normal mode, then insert your card. A dialog box will pop up asking if you want to upload the data from the card into the unit.  Select yes.  Viola!  The user track just shows up as dots on my nav screens, but it's visible and I can follow it if I'm careful driving.  LOL  Hopefully someone who's done this many, many times will chirp in to fill in any gaps I've left.  I'm typing this from memory at work.
Mark
Re: user tracks
« Reply #5 on: June 28, 2012, 07:26:42 PM »
Mark, if you can write this up as a step by step procedure and put it in the tutorials and articles of this forum for others.
Offline mulliemark
Re: user tracks
« Reply #6 on: June 30, 2012, 07:38:14 PM »
thnx ii did get it to work altho those little dots are not the easiest thing to see  with these old eyes ;)
mark
Offline Northwoods
  • Unit(s): 898c SI
Re: user tracks
« Reply #7 on: August 11, 2012, 05:20:39 PM »
Thanks Mark! You helped me remember how to make this work.
I also figured out how to change the small dots to thin or thick lines for us guys with tired eyes. When you get the tracks on your unit. Go into the menu to edit the tracks. There you can change the symbol for the lines from dots to thin lines or thick lines. you can even change the color if you want.
  • Unit(s): 898C SI
  • Software: 6.180
Re: user tracks
« Reply #8 on: August 14, 2012, 09:30:53 AM »
@Northwoods - Sweet!  Thank you for the information!  Much better than the dots!!!  At the rate I'm going, I think I'll have this unit mastered in about 10 years.  lol
Offline Northwoods
  • Unit(s): 898c SI
Re: user tracks
« Reply #9 on: August 14, 2012, 04:45:50 PM »
I know what you meen. It seems that every month or so I'm trying figure out something new. Great unit though! It does everything I want it to once I figure it out.
Last post April 15, 2013, 02:45:25 PM
Last post January 07, 2014, 12:36:21 AM
by Chapaj
Last post April 12, 2014, 08:25:00 PM
by Gimp
Last post February 04, 2015, 10:44:43 PM
Last post May 06, 2015, 05:02:20 PM
Last post April 22, 2016, 04:00:51 PM
by avetjx
Last post April 21, 2020, 11:40:52 PM
Last post May 16, 2020, 08:45:51 AM
