Author Topic: Deleting old tracks  (Read 13352 times)
Offline chuck9012
  • Unit(s): 1198, 798c
  • Software: 4.70
Deleting old tracks
« on: September 29, 2012, 04:41:05 PM »
How do you delete old tracks in the 1198?
Offline George
  • Software: Always up todate
Re: Deleting old tracks
« Reply #1 on: September 29, 2012, 06:07:50 PM »
chuck9012
When you bring up the menu, you will see "Clear tracks", this will clear them for you.
You can also save tracks for later use.  Sometimes you will go over an area that you would like to repeat later.  Unfortunately you cannot save a portion of the track, so if you know the area and can retrace it, clear the track and retrace the are you want and then save it.  Sometimes I do this and make a recording at the same time to view later.
George
« Last Edit: September 29, 2012, 06:11:00 PM by George »
« Reply #2 on: October 01, 2012, 02:16:41 PM »
You will have to go to the “Waypoints, Routes and Tracks” menu (under the “Nav” tab in the main menu system), then go to “Options”, then “Select Multiple and…” and then select “Delete” then you select the tracks that you want to delete and cursor up to “Done” (or just press the EXIT key once) and use the right arrow key to delete the tracks.  You will be asked to confirm your deletion.
Last post February 26, 2010, 01:29:04 AM
Last post June 09, 2010, 03:39:11 AM
Last post January 24, 2015, 05:02:32 PM
by gimez
Last post May 05, 2016, 09:00:18 AM
by Beaulieu80
Last post July 28, 2016, 05:21:03 PM
by afaust
Last post May 16, 2017, 09:46:10 PM
Last post January 10, 2019, 03:01:44 PM
Last post June 15, 2019, 10:09:17 AM
