Author Topic: 997c si side and down image views problem  (Read 11612 times)
Offline prmx
  • Unit(s): 997c si 798 si helix 5 si
  • Software: newer
« on: June 01, 2016, 01:37:03 PM »
hi , need help have a 997c si with new transducer (xhs 9 hdsi 180) , normal sonar views works fine but si and di are not working , too dark, software upgrade to the newer version , transducer select (hd transducer), configuration setup problem ?, here some example pictures of the transducer position and views (examples)
Offline bgathye
  • Unit(s): 1199 HDSI
  • Software: 7.650
  • Accessories: none
Re: 997c si side and down image views problem
« Reply #1 on: June 02, 2016, 09:41:18 AM »
The grass hanging off the transducer is probably not helping  ;D
I am by no means an expert but here is maybe something you might try, seeing as how a normal battery voltage is 12.6ish and yours shows 13.1 that tells me you have your fishfinder hooked up to the cranking battery. Maybe try to hook it up on its own battery and see if anything changes.
Also your transducer does not look like the XHS 9 HDSI 180. From the google searches I find for that it comes up with  the newer longer and thinner transducer.
« Reply #2 on: June 02, 2016, 11:14:00 AM »
Please post the xducer model number printed on the xducer cable about one foot from the connector end ...
Offline mike fish
« Reply #3 on: June 02, 2016, 12:18:50 PM »
HDSI looks to be to the left. That might be a 2D Transducer in center of pic.
I noticed the grass too. LOL! In Minnesota they'd be screaming AIS.
Offline bgathye
  • Software: 7.650
  • Accessories: none
« Reply #4 on: June 02, 2016, 04:04:32 PM »
Oh I see the actual HDSI ducer now. looks like there would be a lot of obstructions with it mounted like that?
Last post July 20, 2011, 03:13:34 PM
Last post October 07, 2011, 07:51:27 PM
by DiveExplorer
Last post April 13, 2012, 01:08:16 PM
Last post February 03, 2012, 08:35:00 AM
Last post May 03, 2013, 09:57:46 AM
by Jay415
Last post July 08, 2014, 11:53:41 AM
Last post August 20, 2015, 12:54:42 AM
