Author Topic: humminbird keeps freezing  (Read 18252 times)
Offline curt66973
  • Unit(s): Helix 9 SI/GPS
  • Software: 4.5.1
« on: May 12, 2016, 08:17:48 PM »
every time I put my SD card in my unit freezes and doesn't  work. iam going to buy a new one any advice on what one i should get. heres one iam looking at Sandisk Extreme SDHC 16GB Class 10 UHS U3 Memory Card, Up to 90MB/s Read Speed
Re: humminbird keeps freezing
« Reply #1 on: May 13, 2016, 12:55:49 AM »
That card should work ...
When you say freezes ... Does that mean the screen goes blank ...??
Go under the Views tab and make the GPS diagnostics view Visible ...
Then exit out of the menus and cycle thru the views until you see the GPS diagnostic screen ...
Watch the 2 boxes in the lower right as you insert the SD Card and see if the unit is recognizing the SD Card before the unit freezes ...
BTW ...weird things happen in these units when the power supply is intermittent or too low from a bad battery or insufficient size wiring ...
Offline curt66973
  • Software: 4.5.1
« Reply #2 on: May 13, 2016, 01:09:24 AM »
Ya when I would power it up if would freeze. I would have to pull the cord to get it to shut off. I called the 1800 # and eventually she had me remove both my cards and then it worked but the second I put the sd card in it would freeze. I put the lake master chip back in and works. I'll try this new card.
« Reply #3 on: May 13, 2016, 01:11:11 AM »
This still sounds like a possible power related issue ...
Have you load tested the battery ... ?? All connections clean and tight ... ??
Offline curt66973
  • Software: 4.5.1
« Reply #4 on: May 13, 2016, 01:18:38 AM »
I bought 3 brand new batteries and it still did it. Connections are good. I'll let u know if a different chip works
« Reply #5 on: May 13, 2016, 10:56:38 PM »
You might format the card ...
And make sure the format is set to FAT32 ...
I'm not versed in what the FAT means ...but I do remember Greg mentioning the format must be in FAT32 ...
Offline N9Phil
« Reply #6 on: May 14, 2016, 08:08:44 AM »
Here are some things I found when I Google "Humminbird formatting SD card".
There is all kind of answers that you can find using Google.
Phil
http://www.thehulltruth.com/marine-electronics-forum/495039-sd-card-questions.html#b
https://www.youtube.com/watch?v=jV1u-x6XhuM
Offline newkid4si
  • Unit(s): 998c si
  • Software: v 5.70
« Reply #7 on: May 14, 2016, 10:03:28 PM »
Phil
    Thanks for the youtube link.
Offline sfw1960
  • Bringer Of The 'Bird
« Reply #8 on: May 15, 2016, 05:56:10 PM »
"File Allocation Table" Rickie....
Last post March 19, 2012, 09:54:41 AM
by cachristian
Last post May 05, 2012, 08:14:47 PM
by Patty
Last post March 04, 2013, 03:46:47 PM
by short grub
Last post August 20, 2013, 02:14:23 PM
Last post January 01, 2015, 01:47:22 AM
by nicko_cairns
Last post July 09, 2015, 01:50:14 PM
by CATNIP
Last post June 06, 2017, 10:40:03 AM
by grizwilson
Last post June 10, 2021, 06:34:34 PM
by ezfishn
