Author Topic: 597 freezing up  (Read 7129 times)
Offline Shawn597
  • Unit(s): 597 ci
597 freezing up
« on: August 10, 2013, 05:31:10 PM »
Hi all first post and its a question!
I have 597 and everytime I re-start my boat it freezes up and I have to take it off its base and re-install...any help would be appreciated!
Re: 597 freezing up
« Reply #1 on: August 20, 2013, 02:14:23 PM »
Welcome to the Humminbird Side Imaging Forums Shawn597.
It sounds like you are starving your 597 unit of the power it needs to operate properly.  Get your battery load tested to see if it is weak.  If it has always done this you may need to look at going to a larger capacity battery and/or changing how your 597 unit is wired to the battery.  Wiring straight to the battery (through a 3-amp in-line fuse) is the best electrical connection option.  Depending on the distance you have to lengthen the standard power cable, you may need to use a heavier wire like a 16 AWG multi-stranded copper wire.  Solder all electrical connections and seal them.  Install a new fuse holder and fuse (I like the flat blade type ones) while you are at it and clean off the battery connections and posts.
Last post March 19, 2012, 09:54:41 AM
by cachristian
Last post May 05, 2012, 08:14:47 PM
by Patty
Last post March 04, 2013, 03:46:47 PM
by short grub
Last post January 01, 2015, 01:47:22 AM
by nicko_cairns
Last post July 09, 2015, 01:50:14 PM
by CATNIP
Last post May 15, 2016, 05:56:10 PM
Last post June 06, 2017, 10:40:03 AM
by grizwilson
Last post June 10, 2021, 06:34:34 PM
by ezfishn
