Author Topic: Unit Freezing When Uploading Tracks  (Read 8176 times)
Offline gametimehoop
  • Unit(s): Helix 5 Sonar GPS
  • Software: 7.730
  • Accessories: No
« on: June 09, 2021, 11:59:12 AM »
HELIX 5 SONAR GPS - Software version 7.730
Unit works great when converting .kml > .gpx > MyhumminbirdPC for uploading waypoints.
However, when trying this for Tracks, the unit freezes up every time.
I have tried:
Restoring factory defaults, clearing all waypoint and track data, uploading only 1 single (5 point) track.  Unit Freezes
Saving track as a .kml then converting to .ht via gpsbabel, then uploading through MyhumminbirdPC.  MyhumminbirdPC forces the .ht file to be converted to .gpx then put it on my card.  Unit Freezes
I have worked with Humminbird technical support for days, and we cannot solve the issue.
Re: Unit Freezing When Uploading Tracks
« Reply #1 on: June 09, 2021, 10:43:46 PM »
What program are you creating the kml track  ... ??
Offline ezfishn
« Reply #2 on: June 10, 2021, 01:30:19 AM »
After clearing the unit, did you try formatting Nav Directory before loading the new data?
  • Software: 7.730
  • Accessories: No
« Reply #3 on: June 10, 2021, 11:11:49 AM »
I am creating .kml files in Google Earth Pro (Desktop application).   Waypoints work fine, just not tracks.
And, no I didn't think i saw the "Format Nav Directories" in the Setup or Navigation tabs.    My unit is a Gen1 Helix 5.  But, I will look for this again.
Offline ezfishn
« Reply #4 on: June 10, 2021, 06:34:34 PM »
Reformat Nav Directory should be under Setup Menu.  May need to set User Mode (Setup Menu) to Advanced or Custom.  The reason I mentioned it was when you erased or delete Nav Data it doesn't correct glitches in the format. Since you have deleted everything, now would be a good time to do it before loading any new data.
Are you using GPSBabel to convert the *.KML file to a *.GDB format (Garmin) before importing to HB PC?  Then when you save it to the SD card, it should be in a Matrix folder as a xxx.HT file for a track.
The attached image shows a couple of tracks created for a tire reef at one of our local lakes and using that same process.
« Last Edit: June 10, 2021, 06:54:38 PM by ezfishn »
Last post October 29, 2010, 02:26:34 AM
by Barmic
Last post March 19, 2012, 09:54:41 AM
by cachristian
Last post May 05, 2012, 08:14:47 PM
by Patty
Last post August 27, 2012, 04:11:04 PM
Last post August 20, 2013, 02:14:23 PM
Last post April 25, 2014, 03:40:47 AM
by slabbacks
Last post June 22, 2016, 09:42:55 AM
by TheGooly
Last post August 14, 2019, 08:34:28 AM
by Mark Saikaley
