Author Topic: Screen freezing up on helix 5si  (Read 24757 times)
Offline CATNIP
  • Unit(s): HELIX 5 SI GPS
« on: July 09, 2015, 11:04:32 AM »
Hi all. I went out fishing sunday afternoon and all was good for an hour or so and then the helix started freezing up. It did it around 10 times and it would last anywhere from 2 minutes to 10 minutes.  It was locked up tight I couldn't power it off or nothing. It did it on several different views and all readouts were also frozen. Power supply is good and battery charged. Any thoughts or ideas?
Re: Screen freezing up on helix 5si
« Reply #1 on: July 09, 2015, 01:36:13 PM »
If you are sure the power supply is in good condition ...
Try Restore Defaults...
Try hiding the "Bird's Eye Views" (if it's the GPS version) ...
Try to find duplicate or weird looking waypoints in the waypoint library (if it's the GPS version) ...
Try with no SD Card in the unit ...
« Last Edit: July 09, 2015, 01:37:55 PM by rnvinc »
Offline CATNIP
« Reply #2 on: July 09, 2015, 01:50:14 PM »
Thanks for the quick response. Birds eye views are off and I have no way points saved. I will remove the navionics card and see if that does it or restore defaults. It just seems like every other time I go fishing something goes goofy with the helix.
Last post December 31, 2014, 09:31:06 AM
Last post November 08, 2015, 01:17:01 PM
by 95Ranger
Last post February 14, 2016, 02:26:33 PM
by N9Phil
Last post December 06, 2017, 09:23:34 PM
Last post May 27, 2016, 05:01:34 PM
by curt66973
Last post May 27, 2016, 04:34:25 PM
Last post July 13, 2017, 09:12:14 PM
Last post August 14, 2019, 08:34:28 AM
by Mark Saikaley
