Author Topic: 997 SI Data Card Specifications  (Read 30896 times)
Offline Gatorcat
  • Unit(s): 997c si
« on: April 21, 2016, 12:50:26 PM »
Hi.  I have a 997C SI that I have used primarily for the sonar and back up Nav.  I decided to start using more of the nav and moving my numbers onto the machine, but it will not read my SD card.
I have now tried two cards.
1. 32GB, 80MB/s speed and SDHC1.
2. 4GB, SDHC
Anyone if these cards should be working and if not, what are the right specs?
Thanks.....
« Last Edit: April 21, 2016, 07:09:45 PM by Gatorcat »
Re: 997 SI Data Card Specifications
« Reply #1 on: April 21, 2016, 11:59:52 PM »
Try taking a screenshot to verify if the card slots are correctly writing data to the inserted SD Card ...
You will have to enable screenshots under the Accessories tab in the Main Menu System ...
Screenshots can be taken in Normal or Simulator ...
Offline Gatorcat
  • Unit(s): 997c si
« Reply #2 on: April 22, 2016, 07:02:15 AM »
Thank you.  I did try the screen shot as my first test which is how I was able to tell the cards are not working.  When I try the screen shot I always get "no writable MMC/SD card found"
« Reply #3 on: April 22, 2016, 01:27:15 PM »
Is the "write protect" switch locked on the SD Card ...??  It's on the left edge of the SD Card itself ...
Are you getting the same message in both slots ... ??
Offline Gatorcat
  • Unit(s): 997c si
« Reply #4 on: April 22, 2016, 07:37:01 PM »
Rickie,
The card is not locked and I get the same message using both slots. I have a feeling the SDHC card is not compatible.  Maybe the system needs an older type of SD card.  Since Humminbird references MMC I have a feeling the unit needs older technology.  My research indicates that MMC was the original SD card technology.
If anyone has SDHC working I their unit, that will help me eliminate that variable.
« Reply #5 on: April 23, 2016, 09:14:05 AM »
I found this that Greg posted a long time ago ...
If you have some really old software in your 997 unit - and I’m talking older than 3.720 here, than you will have to use an SD card to update your unit as one of the updates with the 3.720 version software was the programming to allow the unit to use the SDHC type memory cards.
http://bb.sideimageforums.com/viewtopic.php?t=1088
Do you know what version of software is in your 997 ... ??
Offline Gatorcat
  • Unit(s): 997c si
« Reply #6 on: April 23, 2016, 05:21:06 PM »
That's probably my problem.  I checked and the unit has version 3.66.  Going to dig up on older SD card and see if I can get it updated.
Thanks...
Last post April 23, 2012, 08:52:05 AM
Last post May 09, 2012, 09:31:44 AM
by chaley1964
Last post September 20, 2012, 02:41:28 PM
Last post April 30, 2013, 09:01:19 AM
by N9Phil
Last post May 06, 2013, 03:38:03 PM
Last post July 07, 2014, 01:00:07 PM
by crappie60
Last post March 18, 2018, 03:07:27 AM
by iceperch
Last post October 05, 2021, 11:16:34 PM
