Author Topic: exporting nav data to sd card how do you do it  (Read 9360 times)
Offline crappie60
  • Unit(s): 798 ci hd si
« on: July 04, 2014, 09:23:16 PM »
I have way points and recordings on the unit but I cant get them on the nave card I have a 798ci hd si unit the manual says go to nav tab and highlight Export all nav data , but I don't see this option listed on my nav tab menu. any help would be greatly appreciated
Re: exporting nav data to sd card how do you do it
« Reply #1 on: July 07, 2014, 10:14:24 AM »
Crappie60,
Screen Snapshots and Sonar Recordings are always saved on the SD memory card.
Exporting the waypoints from your 798ci HD Si unit changed with a change in the unit software  Try this instead:
 - Press the MENU button twice and go to the “Waypoints, Routes, tracks” menu.
 - Open this menu by using the Right Arrow.
 - Scroll up to “Options” and open it using the Right Arrow.
 - Select “Select All and…” and use the Right Arrow to open this submenu.
 - Select “Export” and use the Right Arrow to activate this menu.
Offline crappie60
« Reply #2 on: July 07, 2014, 01:00:07 PM »
Thanks Greg, I tried your  info and found the right menu thanks again
Last post September 11, 2012, 06:26:14 AM
by Drifter
Last post January 06, 2014, 11:47:54 PM
Last post February 03, 2014, 07:23:54 PM
by LittleGazoo
Last post June 02, 2014, 10:22:33 AM
Last post July 14, 2014, 09:36:15 AM
Last post June 06, 2015, 08:24:03 PM
by Bubba Canuck
Last post July 09, 2015, 11:34:05 AM
by Carver
Last post October 05, 2021, 11:16:34 PM
