Author Topic: Onix stuck in simulation mode  (Read 11819 times)
Offline jonshoreman
  • Unit(s): ONIX 10 CI SI Combo / 360
« on: September 17, 2015, 07:45:33 AM »
After recently updating the software on my Onix 10 SI it is now stuck in simulation mode.
When I go to the simulation menu I am unable to select the options to turn off simulation mode.
I have perFormed two resets to factory default and the problem persists.
Does anyone have any ideas as to what is causing this issue,mane how I resolve it?
Re: Onix stuck in simulation mode
« Reply #1 on: September 17, 2015, 09:27:34 PM »
Is the xducer still attached ... ??
Is "Demo Mode" on or off (directly under Simulation in the right pane) ...??
Offline N9Phil
« Reply #2 on: September 19, 2015, 09:35:38 PM »
You need to shut your unit down and when you restart it you will get the welcome screen.  If you do not select start normal mode then it will boot up in the simulation mode.  You have to watch for that screen or you will miss it and you are back in simulation.  You will only get this option screen at boot up if your unit is in the simulation mode.
Phil
Last post August 14, 2010, 11:24:01 PM
Last post February 03, 2012, 04:24:23 PM
Last post January 31, 2013, 12:18:59 PM
Last post February 07, 2013, 10:21:40 AM
Last post November 15, 2013, 03:26:01 PM
Last post July 04, 2014, 11:43:12 AM
by Nitro78
Last post July 02, 2016, 12:54:08 AM
by mike fish
Last post March 30, 2019, 07:39:26 AM
by burgersb
