Author Topic: 898si prob  (Read 7038 times)
Offline al49
  • Unit(s): 898si combo
  • Software: first upgrade
  • Accessories: upgrade 2012
898si prob
« on: August 17, 2015, 04:59:18 AM »
hi been a while since on here but hopefully one of the members can help ,I have had a few probs of late with the 898 getting gps readings ,found it was the connection not quite getting into port properly ,but prob is with it being disconnected a few times due to security it has cracked the plastic housing in the main head unit exposing the small brass pin housing at base leaving nothing now to connect to, .do I have to order all the rectangle piece with all female connections on it as it looks like it is a molded piece ,and secondly can I order that section? the male  connection line looks in good condition on the leads cheers AL
Re: 898si prob
« Reply #1 on: August 18, 2015, 01:39:39 AM »
If the connection ports on the head unit are damaged ...the unit will have to be sent to HB for repair ...
1-800-633-1468
Offline al49
Re: 898si prob
« Reply #2 on: August 18, 2015, 04:08:52 PM »
thanks mate thought as much .cheers AL
Last post April 24, 2011, 08:21:05 AM
by Enufzed
Last post May 17, 2011, 01:12:58 PM
Last post June 04, 2012, 06:46:00 PM
Last post September 04, 2012, 04:48:59 PM
by jmerwin321
898si hd
Started by garm 898c SI
Last post November 09, 2013, 10:45:08 AM
by JDX
898si hd
Last post March 19, 2014, 08:15:56 PM
by slabbacks
Last post April 28, 2016, 01:35:06 AM
Last post August 04, 2016, 09:18:39 AM
by larry crouch
