Author Topic: another 898si question  (Read 8866 times)
Offline al49
  • Unit(s): 898si combo
  • Software: first upgrade
  • Accessories: upgrade 2012
« on: April 25, 2016, 05:04:08 AM »
hi all ,another question for you gurus ,as I have had no luck with the hummingbird company with replies back to me here in aussie,it has been 12 months now since I lost the gps capabilities with the small brass female pin breaking.the question is can I use any of the other 3 ports to rechannel the gps to the antenna.this might be me buying another gps ariel to fit this if possible. only a thought as I have exhausted my option s from here in aus.even Johnson outdoors hasn't replied to my email,maybe too hard basket .
Re: another 898si question
« Reply #1 on: April 25, 2016, 11:37:40 PM »
I don't know any way that the GPS signal can be obtained directly thru one of the other sockets ...
You could subscribe to a different GPS antenna from another unit in an Ethernet Setup ...
Try this number for international straight to Eufala ...
Johnson Outdoors Marine Electronics
Humminbird®
678 Humminbird Lane
Eufaula, AL 36027
Tel: 334-687-6613
Fax: 334-687-0503
Businesses: Marine Electronics
Offline al49
« Reply #2 on: April 26, 2016, 02:14:14 AM »
thanks rickie ,will try again
Offline al49
« Reply #3 on: April 28, 2016, 01:29:06 AM »
after having another look at unit decided to take it down to local marine electriton and ask if it is possible to solder new wires onto broken brass pins ,he said he would give it a go as it wouldn't hurt as unit has to go back and have a new back section put on it .he found there was a prob also with the main power pins not connecting properly as well which was causing it to reboot every now and then .soldered on new pin acceptors and bugger me it is working perfectly .saves a lot of dramas getting it to states for repair thanks rick for all your help greatly appreciated .cheers AL
« Reply #4 on: April 28, 2016, 01:35:06 AM »
This is good news ...
Last post May 17, 2011, 01:12:58 PM
Last post May 27, 2011, 12:02:12 PM
Last post June 04, 2012, 06:46:00 PM
Last post September 04, 2012, 04:48:59 PM
by jmerwin321
Last post April 04, 2013, 10:33:49 AM
898si hd
Started by garm 898c SI
Last post November 09, 2013, 10:45:08 AM
by JDX
898si hd
Last post March 19, 2014, 08:15:56 PM
by slabbacks
Last post August 18, 2015, 04:08:52 PM
by al49
