Author Topic: Humminbird 898si/ci  (Read 11395 times)
Offline larry crouch
  • Unit(s): 898c&586hd
  • Accessories: lakemaster and navionic
Humminbird 898si/ci
« on: August 03, 2016, 03:21:23 PM »
I also have an 899 humminbird and on the 899 it has a simulator mode in the chart view and the 898 does'nt seem to have that feature and if it doe's I sure have not found . So what I'd like to know is doe's the 898 have a spot for the map simulator? Thanks for the help.  Larry
Re: Humminbird 898si/ci
« Reply #1 on: August 03, 2016, 10:53:19 PM »
All the HB units have 2 separate simulators ...
The "Demo Simulator" is what the retail stores use for customer demo ... It has balloon info popups explaining features of the unit as the different views rotate thru a shuffle scenario ... Any settings changes made during "Demo Simulator" are not saved after a power cycle (so that customers can change settings all day and the store can start fresh with a simple power cycle) ... Demo Simulator can be shut off under the Setup tab so that it ceases to be an option upon startup ...
The "Forced Simulator" can only be found by pressing the "Menu" button upon boot up to give the option popup of Normal Operation - Forced Simulator - or System Status ... Any settings changes made during "Forced Simulator" are saved even after a power cycle ...
Forced Simulator "simulates" a GPS antenna attached so that the Chart views are available for user input without the GPS antenna actually having to connect to the satellites ...
« Reply #2 on: August 04, 2016, 09:18:39 AM »
Thanks Rickie for the information on the 898. Without you and the team there would be a lot of lost people like myself out there wondering. Thanks again for your help. Larry.
Last post May 17, 2011, 01:12:58 PM
Last post June 04, 2012, 06:46:00 PM
Last post September 04, 2012, 04:48:59 PM
by jmerwin321
Last post January 26, 2013, 08:55:06 PM
Last post June 18, 2013, 07:32:50 PM
by elkaddict
Last post July 18, 2013, 01:05:07 PM
by iceimanhunting
898si hd
Started by garm 898c SI
Last post November 09, 2013, 10:45:08 AM
by JDX
898si hd
Last post March 19, 2014, 08:15:56 PM
by slabbacks
