Author Topic: 898si hd  (Read 7050 times)
Offline garm
  • Unit(s): 898sihd
  • Software: 6.490
898si hd
« on: March 19, 2014, 07:20:08 PM »
will be putting boat back in the water end of month will the moss build up on the transducer effect my readings fixed me something that I think I can clean the transducer with that will keep most off . also I am going to post some pictures of transducer placement soon so any thoughts will be nice. I used it some last fall really cant figure out how my readings look, these was my last time out last year
Offline slabbacks
  • Is it Friday yet!
  • Software: 6.490
Re: 898si hd
« Reply #1 on: March 19, 2014, 08:15:56 PM »
gram
  Do you remember what the chart speed was?  I notice various boat speeds and this can greatly effect the image you get back.  In SI it ranges from .7 - 8.5.  When running a pattern or search of a area get a base boat speed and chart speed and keep using it.  Later you will learn that by upping the chart or lowering the chart it will help in other ways but first learn a base speed your unit likes.
5.4 looks better going under what I take was a bridge or something with pilings.  Did you have SI Enhance sharpness on anything other that "OFF"?  It looks a little grainy is the reason I asked.  Once you find a good location you can change it to low/med./high to get the fish to pop out in the image for you.
DI is effected the same way in your first DI shot.  The last one is better showing bait, thermo and it looks as though you went by pilings with one of them being closer to the boat than the other.
With a boat speed set at or just bellow your chart speed based off those good shots you should see good images.  The other stuff was just settings type issues from what I saw and some of the others may jump in to see if I'm on the right track.
As far as build up on the transducer I know some here that use Tilex and wipe the xducer down with it.  These are guys who keep the boat in the water at the slip all summer.
Hope it helps and let us know how it goes.
Tell them I've gone fishing!
Last post May 17, 2011, 01:12:58 PM
Last post June 04, 2012, 06:46:00 PM
Last post September 04, 2012, 04:48:59 PM
by jmerwin321
898si hd
Started by garm 898c SI
Last post November 09, 2013, 10:45:08 AM
by JDX
Last post November 19, 2014, 12:42:02 PM
by rnormanr
Last post August 18, 2015, 04:08:52 PM
by al49
Last post April 28, 2016, 01:35:06 AM
Last post August 04, 2016, 09:18:39 AM
by larry crouch
