Author Topic: Humminbird PC will not install  (Read 14665 times)
Offline gwraith
  • Unit(s): 788ci
  • Software: 5.840
« on: August 05, 2014, 08:32:46 PM »
Have tried to install the latest version of Humminbird PC but the file which I downloaded directly from Humminbird install a program called DriverTuner.. Have tried several times and several different  versions.  Any help would be greatly appreciated.
Offline sfw1960
  • Bringer Of The 'Bird
Re: Humminbird PC will not install
« Reply #1 on: August 05, 2014, 09:27:05 PM »
You certainly don't have the right file then - "DriverTuner" is not required and may be malware??
HumminbirdPC (Version 4.3.8) is the most recent.
I have used it on Windows XP and Windows 7 (64 bit) - I have not tried it on Windows8/81.
This link may or may not work for you....
https://879dd651a809fc1b59de-035169dcc8fb0db4e46082ec8002cac8.ssl.cf2.rackcdn.com/HumminbirdPC_v4_3_8.exe
Or try here:
http://forums.sideimagingsoft.com/index.php?action=downloads;cat=12
Good luck!
« Last Edit: August 05, 2014, 09:28:10 PM by sfw1960 »
Offline gwraith
  • Unit(s): 788ci
  • Software: 5.840
« Reply #2 on: August 05, 2014, 11:12:58 PM »
Downloaded the software from the link you provided and the same thing happened.  I think perhaps I have a virus on my computer that forces the install of the wrong software.  Thanks
Offline sfw1960
Offline gwraith
  • Unit(s): 788ci
  • Software: 5.840
« Reply #4 on: August 06, 2014, 03:39:46 PM »
Definitely something going on with my computer.  Still can"t install Humminbird PC from my hard drive but was successful using a flash drive.  Thanks for the help and suggestions.
Offline LittleGazoo
  • Software: 3.640
  • Accessories: Ethernet
« Reply #5 on: August 06, 2014, 05:04:25 PM »
HBPC Installation has a long time bug.
Installation can fail if another SETUP.EXE is in the same folder.  That is sometimes why another installation procedure will start...
Make sure the HBPC installation program is in a folder by itself.
Offline sfw1960
« Reply #6 on: August 06, 2014, 06:17:53 PM »
Never had that problem LG...
There is quite a bit about "DriverTuner" being possible malware - so unless the OP chimes in with that saying there's another EXE in the same folder - I am betting on an infection.........
http://www.herdprotect.com/setup.exe-3851fc1b1715a7052587bd430aa18b9aadad4b1b.aspx
https://forum.avast.com/index.php?topic=143306.0
Offline newkid4si
  • Unit(s): 998c si
  • Software: v 5.70
« Reply #7 on: August 07, 2014, 12:29:08 AM »
I'm placing my bet on LittleGazoo.
       Mike
Offline LittleGazoo
  • Software: 3.640
« Reply #8 on: August 07, 2014, 11:37:55 AM »
Could be an infection or download add-on from third-party hosting site(but not when directly downloaded from HB).
Problem I stated is doc'ed here:
http://forums.sideimagingsoft.com/index.php?topic=6809.0
Last post July 04, 2010, 11:41:45 AM
by Vlad T. Impaler
Last post January 17, 2012, 11:20:22 AM
Last post May 31, 2012, 11:43:17 AM
by doug10
Last post May 01, 2013, 11:31:40 AM
by 4d-rock
Last post April 27, 2014, 03:59:41 PM
by Goosedwnr
Last post February 09, 2016, 12:49:01 PM
Last post August 22, 2016, 02:30:31 PM
Last post May 04, 2024, 07:47:36 PM
