Author Topic: humminbird 999 si hd install on a yamaha fhs 190  (Read 10330 times)
Offline montanacarpenter
  • Unit(s): 999 ci hd
« on: August 22, 2016, 09:28:26 AM »
when looking at the transome on the fhs 190 there no place to install the transducer where the jet drive does not block the view anyone had any sucess installing one on these boats thanks
Re: humminbird 999 si hd install on a yamaha fhs 190
« Reply #1 on: August 22, 2016, 02:30:31 PM »
It will get a little expensive, but this is one of the scenarios where you might consider a http://www.humminbird.com/Products/AS-SILR-Y/ and 2 SI transducers.
I saw a YouTube video where the guy mounted the transducer at an angle on the right side of the hull .... I wouldn't recommend doing that if you want to get good SI images.  With one side angled down, one side will be "hot" and the other side "dim".
Well, might as well go ahead and post the link.....but I would not recommend this.  https://www.youtube.com/watch?v=9CTFjn4rB9o
A second option would be to epoxy an actual thru hull transducer... not shoot thru.... but not many people want to drill a hughe hole in their transom.
I'd go with 2 SI transducers.... one on each side....and if that hull will support a shoot thru, put a 2D transducer in the bilge to get high speed depth readings.....You may have to talk to Yamaha to find out if the hull will support the shoot thru 2D and if they can tell you a likely place to put it.
« Last Edit: August 22, 2016, 02:51:30 PM by Bob B »
Last post January 17, 2012, 11:20:22 AM
Last post October 30, 2014, 11:01:08 AM
by viper200
Last post May 01, 2013, 11:31:40 AM
by 4d-rock
Last post August 28, 2014, 09:09:17 AM
by viper200
Last post August 07, 2014, 11:37:55 AM
by LittleGazoo
Last post February 09, 2016, 12:49:01 PM
Last post July 25, 2017, 08:03:59 AM
Last post March 29, 2023, 07:13:18 AM
by N9Phil
