Author Topic: 788 install help?  (Read 7939 times)
Offline fishinman
  • Unit(s): 1
788 install help?
« on: January 16, 2012, 05:34:00 PM »
I exchanged my in-dash Lowrance x-125 (finally) for a HB 788 combo in the front dash (drop-in) of my Triton.....The problem I need some help on is a way to solid the unit up in the drop in so it won't bounce out....The Lowrance had screws on the sides to attach to a bracket in the drop in, but not the 788....Any ideas or help?
fish'
Re: 788 install help?
« Reply #1 on: January 16, 2012, 06:08:16 PM »
For our purposes where we use the units in a box to make them portable, we make a bracket similar to the lowrance so that we can secure the unit in the faceplate.
« Reply #2 on: January 17, 2012, 10:08:38 AM »
fish’,
There is an indash mounting kit (IDMK-700  http://store.humminbird.com/products/322979/IDMK_700 ) that is available for the 788c or 788ci unit.  If you have the 788ci HD version unit you will need the IDMK-700E accessory.  Basically this is a U-bracket that mounts across the back of the unit and presses the unit against the dash.  There is also a cable connector holder to make sure the cables remain attached.
« Reply #3 on: January 17, 2012, 11:20:22 AM »
The cable holder is a must for the in-dash. Unless you can get to the back easily. Although it is not a good idea to have cable come loose when powered on.
Last post February 06, 2012, 07:26:09 AM
by stillbear
Last post January 02, 2013, 04:44:32 PM
Last post January 30, 2013, 12:58:16 PM
by mjsimon88
Last post March 12, 2013, 06:39:52 PM
by Aussie
Last post February 12, 2014, 06:12:32 PM
by N9Phil
Last post February 25, 2014, 10:38:42 AM
Last post January 26, 2019, 06:08:30 PM
by WiNorthOutdoors
Last post May 04, 2024, 07:47:36 PM
