Author Topic: New Install  (Read 9532 times)
Offline proskeeterman@comcast.net
  • Unit(s): 997c Nav Helix 7 Si G3
  • Software: 6.300
  • Accessories: None
New Install
« on: May 03, 2024, 07:01:30 PM »
Wanted to know if slo mo fuses are necessary on the 12 n 15 Solix?
Re: New Install
« Reply #1 on: May 03, 2024, 09:00:52 PM »
While slo blow fuses are recommended, I’ve never found a reliable source for getting them  ...
Correct size fuse as indicated in the installation manual would be more important  ...
  • Software: 6.300
  • Accessories: None
Re: New Install
« Reply #2 on: May 04, 2024, 11:14:44 AM »
I did find slo blo (tube type) fuses, so if I can use them, that's better  Yes?? But a regular 5a for the Solix 12 and a 7.5a for the 15, will work, Yes?  Do you recommend putting them closer to the unit or to the battery? Sorry for all the questions but I'm just trying to do this as right as I can. Really appreciate you guys and this site.
Re: New Install
« Reply #3 on: May 04, 2024, 07:47:36 PM »
Installation manual says “as close to the battery as possible” ...
https://humminbird-help.johnsonoutdoors.com/hc/en-us/articles/9216210775831-In-line-Fuse-Installation
SOLIX 10 and 12 =5amp
SOLIX 15 = 7.5amp
« Last Edit: May 04, 2024, 07:49:51 PM by rnvinc »
Last post November 13, 2011, 04:02:06 PM
by stevemc
Last post November 21, 2011, 10:21:10 AM
Last post January 17, 2012, 11:20:22 AM
Last post May 31, 2012, 11:43:17 AM
by doug10
Last post May 01, 2013, 11:31:40 AM
by 4d-rock
Last post April 11, 2014, 12:40:41 PM
Last post April 16, 2014, 05:03:00 AM
by garm
Last post April 30, 2015, 08:30:13 PM
by Jimmy B
