Author Topic: exporting data to google earth  (Read 9910 times)
Offline gros21
  • Unit(s): 1197
  • Software: latest
« on: September 11, 2012, 02:51:17 AM »
well i think humminbirdpc now export to google earth as well can also export all waypoints? and label them nice and easy?
Is there any real reason to use sonar trx anymore?
Offline Drifter
  • Shade Tree Mechanic
    • Limbatus.Net Info
  • Unit(s): 737 / 798ci SI / 997c SI / HBPC
  • Software: 4960/6300/6300/4.3.3
  • Accessories: Razorfish (3) ~ WeatherSense
Re: exporting data to google earth
« Reply #1 on: September 11, 2012, 05:53:30 AM »
Hi gros21,
I would think SonarTRX would be used mainly for visualization of side scan sonar recordings and it's ability to combine multiple recordings into a single "bottom structure map". Humminbird PC has had the ability to View in Goggle Earth for many years (although there were periods where it was dependent on using older versions of Goggle Earth). Viewing GPS data in Goggle Earth allows visualization of waypoints, routes and tracks. Seeing bottom maps or waypoints overlaid on a larger map helps to put them in perspective and gives them more meaning.
There are many different programs that allow you to edit GPS data. I still use Garmin Mapsource. Which ever editing program you use is up to you. Just make sure you can get your edited GPS data back onto your Humminbird unit. In most cases that would mean getting your edited GPS data saved into a GPX file format. That would let you open the file in Humminbird PC so you could transfer it to your unit. Also you should verify your edited GPS data by making sure that something like a waypoint for your local dock still shows up where it is should be when you go back out the next time.
Darrell
Edit - Here is a link on getting a Google Earth file converted to a GPX file (which has a link to GPSBabel) ...
 http://support.google.com/earth/bin/answer.py?hl=en&answer=182525
« Last Edit: September 11, 2012, 05:59:26 AM by Drifter »
Offline gros21
  • Unit(s): 1197
  • Software: latest
« Reply #2 on: September 11, 2012, 06:12:02 AM »
I want to map out my full local river system since it was flooded every thing has changed.
And maybee view all my marks on google earth.
Offline Drifter
    • Limbatus.Net Info
« Reply #3 on: September 11, 2012, 06:26:14 AM »
Hi again gros21,
If all you want to do is view waypoints and tracks in Goggle Earth, then it is very easy to just go from HB PC straight to Goggle Earth. For my region, Goggle Earth has a function that lets you look at Historical Imagery. Depending on what is available for your area, it might show your river at different levels.
Link: http://www.gearthblog.com/blog/archives/2009/02/google_earth_5_historical_imagery.html
Darrell
Last post March 14, 2010, 02:42:18 PM
by stillbear
Last post June 04, 2010, 11:31:25 AM
by benamen
Last post August 24, 2011, 04:02:41 PM
by War Eagle
Last post January 06, 2014, 11:47:54 PM
Last post February 03, 2014, 07:23:54 PM
by LittleGazoo
Last post June 02, 2014, 10:22:33 AM
Last post July 07, 2014, 01:00:07 PM
by crappie60
Last post July 09, 2015, 11:34:05 AM
by Carver
