Author Topic: Exporting survey data by dropbox from the SD card??  (Read 14750 times)
Offline tiburon78
  • Unit(s): 1198 SI hd combo
  • Software: Humminbird PC
« on: February 03, 2014, 12:38:54 PM »
Hi,
A friend did a survey and sent me all data by dropbox... the thing is that I can't open it? in humminbird PC and humviewer it says that the files have error?
I guess the editing most be directly from the SD card?? or not??
Thanks!!!  :-[
Re: Exporting survey data by dropbox from the SD card??
« Reply #1 on: February 03, 2014, 01:49:21 PM »
What file(s) did he send you and what was the file extension of each?
Are these Sonar Recordings?
Offline tiburon78
« Reply #2 on: February 03, 2014, 02:17:51 PM »
Hi,
I got .IDX och .SON in a archive and .DAT and .XML in Another....
Offline LittleGazoo
  • Software: 3.640
  • Accessories: Ethernet
« Reply #3 on: February 03, 2014, 04:11:39 PM »
He's sent you a Recording.
A recording should be a folder containing for example:
  A folder called R00102
  A file called R00102.DAT
The R00102 folder will contain .SON and .IDX files:
  B001.SON, B001.IDX
  B002.SON, B002.IDX
  . . . etc
The FOLDER and the .DAT file must be matching names.
I believe the .XML is created after Hummview has opened and process this data.
Hopefully he has archived the top-level folder:
  Folder                           <--- Archive and send this folder
    R00101 folder
    R00101.DAT
    R00101.XML
Thus expanding & recreating the file-structure is a little easier.
« Last Edit: February 03, 2014, 04:13:01 PM by LittleGazoo »
Offline salado
  • 798ci HD si
  • 798CiHD
    • youtube
  • Unit(s): 798ci HD si
« Reply #4 on: February 03, 2014, 05:38:48 PM »
Offline tiburon78
« Reply #5 on: February 03, 2014, 06:28:55 PM »
Hi!! yes I got those files!! How do I look at the sonar files??
Offline salado
  • 798ci HD si
  • 798CiHD
    • youtube
« Reply #6 on: February 03, 2014, 06:39:21 PM »
I use HumViewer.
http://forums.sideimagingsoft.com/index.php?topic=172.0
<file>, <open>, and select the *.DAT file
Offline LittleGazoo
  • Software: 3.640
« Reply #7 on: February 03, 2014, 07:23:54 PM »
I use HumViewer.
As Salado says.  But you might wish to always first do: Settings-->Unit Settings cause the defaults always meters.
Last post May 09, 2012, 09:31:44 AM
by chaley1964
Last post September 11, 2012, 06:26:14 AM
by Drifter
Last post September 20, 2012, 02:41:28 PM
Last post January 06, 2014, 11:47:54 PM
Last post June 02, 2014, 10:22:33 AM
Last post July 07, 2014, 01:00:07 PM
by crappie60
Last post June 06, 2015, 08:24:03 PM
by Bubba Canuck
Last post July 09, 2015, 11:34:05 AM
by Carver
