Author Topic: Transducer Question  (Read 7117 times)
Offline MadTownGator
  • Unit(s): 598ci HD SI Combo, 345c
Transducer Question
« on: June 30, 2014, 02:23:01 PM »
I was wondering if the XP 14 20 and the XTM 9 20 T are essentially the same transducer?  I have a XTM 9 20 T that I do not plan on using, but have been considering a through hull for when I run on a shallow river with a lot of sandbars.  Can I just epoxy the XTM 9 20 T to the hull (it's fiberglass), and be good to go or do I actually need the XP 14 20?
Thanks,
CC
Re: Transducer Question
« Reply #1 on: June 30, 2014, 03:10:35 PM »
CC, What unit is this for?
The XP-14-20 is made for the ONIX/ION units. Although it is s basic 20/60 degree 200/83kHz transducer it has a different connector than the XTM-9-20-T transducer and it also has some internal electronics for transducer detection and identification.
« Reply #2 on: June 30, 2014, 04:51:15 PM »
The unit I am working with is a 598Ci HD SI Combo. It's possible this unit won't support multiple transducers, I honestly haven't looked at that yet.  I was checking my options from a transducer point of view.  I also have a spare XNT 9 20 that I can throw in the mix.
« Reply #3 on: July 02, 2014, 01:12:18 PM »
CC,
Either the XTM-9-20-T or the XNT-9-20 can be epoxied inside-the-hull and connected to an AS-Si-DB-Y cable (along with the CSi transducer that came with the 598ci HD Si unit).  Whichever one is installed will serve as the 2D sonar for your 598 unit.
Last post March 25, 2010, 12:14:33 PM
by jclark
Last post October 16, 2011, 10:56:58 PM
by Roddy
Last post May 20, 2012, 11:22:34 PM
by GoldenDawn1
Last post May 30, 2012, 03:40:06 PM
Last post November 27, 2012, 12:57:16 PM
Last post November 27, 2013, 05:57:32 PM
Last post March 11, 2014, 03:14:15 PM
Last post March 16, 2014, 10:23:37 PM
by chuck41
