Author Topic: Transducer question  (Read 7006 times)
Offline Sigler
  • Unit(s): 1198c 788ci di
  • Accessories: interlink
Transducer question
« on: November 22, 2012, 11:25:23 AM »
I have a friend that bought a 798 and mounted the transducer on the back of his boat. He is wanting to use the same graph and put a transducer on his trolling motor. What transducer does he need and what type of box will he need to hook them up? Thanks
Offline George
  • Software: Always up todate
Re: Transducer question
« Reply #1 on: November 22, 2012, 12:30:45 PM »
Sigler
Is he going to move the Head unit to the trolling motor and to the console?  If so then he will need hook it up as a single unit.
Humminbird has the TS3 transducer switch to go between the two transducers, personally I liked the older toggle switch better, but it is no longer produced.
These are the trolling motor transducers that I could find listed on HB's site :XTM 9 HDSI 180 T, XTM 9 SI 180 T
I am pretty sure there are others.
What you need depends on how it is going to be used.
George
Offline Sigler
« Reply #2 on: November 24, 2012, 07:33:06 AM »
The unit is on the front of the boat he has a tracker boat with the steering up front
« Reply #3 on: November 27, 2012, 12:57:16 PM »
So he will not be moving the unit – just connecting a second transducer (that is mounted on the trolling motor) to it.  The TS3 Transducer Switch and XTM-9-Si-180-T transducer that George mentioned will do the trick.
Last post March 25, 2010, 12:14:33 PM
by jclark
Last post May 30, 2012, 03:40:06 PM
Last post November 27, 2013, 05:57:32 PM
Last post March 11, 2014, 03:14:15 PM
Last post March 16, 2014, 10:23:37 PM
by chuck41
Last post July 02, 2014, 01:12:18 PM
Last post December 22, 2014, 05:50:11 PM
by jjbch
Last post December 28, 2014, 09:56:15 PM
