Author Topic: 997 transducer question  (Read 12865 times)
Offline jclark
  • Unit(s): 997 SI
« on: March 25, 2010, 08:16:04 AM »
if i have nicks on the bottom off the transducer, can they be wet sanded down smooth. will that effect the Si/Di/2D sonar's performance .
Re: 997 transducer question
« Reply #1 on: March 25, 2010, 08:48:38 AM »
Nicks in the bottom may be ok if they are small.  Nicks on the side of the transducer may affect the SI a little.  If they can trap air bubbles, then you will surely have problems.  If you do sand them, make sure you finish with a very fine paper.
The SI elements are on the outside edge looking down at 30 degrees. Here is a diagram.  As long as you dont have any nicks in the blue area, you will probably be fine.
Good Luck,
Offline jclark
  • Unit(s): 997 SI
« Reply #2 on: March 25, 2010, 12:14:33 PM »
Thanks robert. they are on the bottom and i thought that was why i was losing my 2D sonar at speeds >14mph.
Last post October 20, 2009, 09:00:54 AM
Last post October 13, 2009, 09:29:33 AM
Last post May 06, 2010, 04:02:06 AM
Last post August 19, 2010, 11:49:07 PM
by ericd
Last post September 11, 2010, 10:10:15 AM
Last post February 23, 2011, 05:00:52 PM
Last post March 31, 2011, 02:49:23 PM
by jjbch
Last post October 16, 2011, 10:56:58 PM
by Roddy
