Author Topic: Another transducer question  (Read 7121 times)
Offline chuck41
  • I'd rather be fishin'
    • Lake Ouachita Arkansas
  • Unit(s): 798ci si di Combo
« on: March 16, 2014, 11:23:11 AM »
Yesterday I was fishing in my party barge and suddenly noticed it was drifting near a clay bank.  By time I could get back there and push away that expensive 789ci si transducer was banging against the bank.  Didn't do any damage this time but made me very nervous.
If I move that unit to in front of the motor and get another transducer for the "high speed" (relative term for barge) to mount on the "toon" which would be a good choice for an inexpensive 200/83 khz down looking one in a transom mount?   I would use a splitter to connect the two.  Also what splitter would work with that combo?
Don't want to have that argument with the wife after destroying a $200+ transducer.
A bad day on the lake is still better than a good day at work!
Re: Another transducer question
« Reply #1 on: March 16, 2014, 09:44:21 PM »
The XNT 9 20 is a transom mount 83kHz/200kHz Dual beam...
http://www.humminbird.com/Products/XNT-9-20/
The AS SIDB Y is the cable you would need to allow the 83kHz/200kHz Dual Beam to obtain 2d readings ...and allows the HDSI xducer to be mounted in a safer place on the vessel...
http://www.humminbird.com/Products/AS-SIDB-Y/
There are no menu selections to change in the unit with this setup because the AS SIDB Y cable is basically a "channel"splitter that disconnects the 2d piezo from the HDSI and routes the 2d "channel" to the 83kHz/200kHz Dual Beam xducer instead...(the unit "sees" this as 1 xducer)..
Offline chuck41
« Reply #2 on: March 16, 2014, 10:23:37 PM »
Rickie,
Many thanks. This is exactly what I needed.
Last post March 25, 2010, 12:14:33 PM
by jclark
Last post June 10, 2011, 10:16:32 PM
by Roddy
Last post October 16, 2011, 10:56:58 PM
by Roddy
Last post May 20, 2012, 11:22:34 PM
by GoldenDawn1
Last post May 30, 2012, 03:40:06 PM
Last post November 27, 2012, 12:57:16 PM
Last post November 27, 2013, 05:57:32 PM
Last post March 11, 2014, 03:14:15 PM
