Author Topic: 998 c si to 788ci HD DI with Ethernet ?  (Read 11692 times)
Offline SkeeterMatt
« on: June 25, 2014, 04:29:24 PM »
I was told these two units will share way points but I have never been able to get it to work. Will they share data or was I mis-led? I downloaded the ethernet manual and follwed it to the letter but I can't get them to share.
Offline bobcoy
  • Unit(s): 1197 & 1198
  • Software: 6.640 & 7.670
Re: 998 c si to 788ci HD DI with Ethernet ?
« Reply #1 on: June 25, 2014, 04:40:08 PM »
Do you have the latest updates? Bob
« Reply #2 on: June 26, 2014, 01:09:26 AM »
Ethernet-ed units can "see" each other's waypoints if...:
*Both units are powered on...
*Both units are enabled to "Share Waypoints" under the network tab...
http://forums.sideimagingsoft.com/index.php?topic=2052.0
The waypoints from the Slave unit will be seen in Green text on the Master unit's chart views...(the Master unit is the unit the waypoint was actually "Marked" on...)
Physical transferring of waypoints from one unit's memory to another unit's memory is not accomplished with Ethernet ...(as it was in the old Interlink system)...
« Last Edit: June 26, 2014, 01:11:49 AM by rnvinc »
Offline SkeeterMatt
« Reply #3 on: June 26, 2014, 12:51:08 PM »
i haven't updated either unit in a while. Last time I did the 998 went haywire and had to be sent in to be repaired. So if I mark a waypoint on the 998 at the helm, it should show up on the 788 on the bow as long as both units are powered on and enabled?
Thanks for the replys....
Matt
« Reply #4 on: June 26, 2014, 12:54:31 PM »
So Matt... what software version are you running in each unit?
Offline SkeeterMatt
« Reply #5 on: June 27, 2014, 10:14:07 AM »
Greg,
The 998 software is 6.18 and the 788 is 6.25
« Reply #6 on: June 27, 2014, 11:00:37 AM »
Those software versions should work together.
Offline SkeeterMatt
« Reply #7 on: June 27, 2014, 11:14:44 AM »
ok, thanks Greg. I will keep trying, I must be doing something wrong. Should they share existing waypoints and routes from an SD card or will they only share the ones created real time on the water?
« Reply #8 on: June 27, 2014, 11:37:08 AM »
If you load waypoints, routes and tracks with an SD card they are loaded into that unit’s memory and they should work just like they were originally made on that unit.
Offline SkeeterMatt
« Reply #9 on: June 27, 2014, 11:49:10 AM »
so they will not share previous recorded points? Say i'm in the garage and power on both units, insert an sd card, should I be able to see the same points on both units or only the one with the SD card in it?
« Reply #10 on: June 30, 2014, 01:25:41 PM »
Yes and yes.
When you insert the SD card with the waypoints on it into one unit they should load into that unit.  Those same waypoints will be than shared with the second unit.
Offline SkeeterMatt
« Reply #11 on: July 02, 2014, 09:58:13 PM »
I deleted all nav data from both units, to be sure I was loading fresh waypoints. I went to the lake today and inserted sd card with only that lake on it. Both units showed the same new waypoints. Then I marked a new waypoint at the helm and low and behold it was on the 788 on the bow! Awesome stuff! Thanks for all of your help!
Matt
Last post April 03, 2011, 03:41:03 AM
by boat49
Last post March 25, 2011, 07:13:30 PM
by ferney69
Last post March 28, 2011, 02:11:09 PM
Last post September 14, 2011, 07:19:26 PM
by mck1975
Last post December 10, 2011, 08:20:43 PM
by DLM10
Last post December 24, 2011, 01:24:42 PM
by SkeeterMatt
Last post March 15, 2012, 10:01:39 AM
by gibsond
Last post February 18, 2014, 09:23:13 AM
